How to resolve the Whirlpool F65 Washing machine 'FE' error.
appldoctom
  • 311 Answers
SOURCE: Whirlpool Washing Machine, Product- F65, model7234,water overflow
top loader?usually its because your water valve is not closing because minerals have gotten into the water valve.but water would come into washer even when unpluged.another thing can be if when over flowing and u unplug it and it stops fillig/over flowing.your presure switch hose will have come off the water level switch or a mouse chewed a hole in it.its a clear tube thats running from your water level switch.i hope that helps god bless,tom
Posted on Jan 01, 2009
  • 1550 Answers
SOURCE: the error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Posted on Feb 21, 2009
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
  • 234 Answers
SOURCE: FE error is displayed in my whirlpool washing machine what to do?
How do you know this is a generic problem for all whirpool washers?
What I can tell you is: ever since electronic controls were placed with appliances (dishwhrs, dryrs, wshrs, frigs,etc) there was this new age of error and fault codes that would lock-up the electronics. I always recommend people buy the mechanical control appliances because you do not have these interim problems. Mechanics justs keep ungoing, and if it will fail some day, you usually have a warning period, and it is more likely to be cheaper to repair than electronic controls.
Aside from all that, your owners manual should have a section in the rear that says trouble shooting; this usually has some of the standard error/fault codes and it can tell you what it stands for. Most errors can be eliminated by unplugging this electric cord and waiting 1 minute for the ciruit board to reset itself. The usual causes are: out of balance load that shook the machine too much, an overfill of water level, and overload of too much heavy close that caused the machine to strain the engine, or a short temporary power interuption while the machine was operating. Try the plug rest method and pay better attention to the load/overload. Hope all will be good. Macgivor
Posted on Oct 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washing machine model wfw9500tw01
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Whirlpool f65 whitemagic top load washingmachine pe error
consult the user manual from the Whirlpool website eric
Jan 05, 2018 | Whirlpool Washing Machines
Whirlpool F65 PE Error?
F65 STEAMER TIME OUT REACHED Error
happens if there is no communication between Central Control Unit (CCU) and steamer electronic board. The failure will reset after running the Diagnostic Test Program. 1. Check connections between the Steamer Electronic board and CCU.
2. Check mains supply is in range (90V-132V).
Jan 03, 2015 | Whirlpool Washing Machines
WhirlPool PE Error
PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover.
Nov 10, 2012 | Whirlpool Washing Machines
P.c.b. not working
Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
Oct 21, 2012 | Whirlpool Washing Machines
I got PE error code in my whirlpool white magic F65
The PF error code indicates a power failure on many different machines. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle.
Aug 13, 2012 | Washing Machines
I get a PE error code
I get PE error code in whirlpool white magic F65
Aug 12, 2012 | Washing Machines
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
Whirlpool washing machine F65
Filter is blocked where hose connects to machine or water valve faulty.
Sep 03, 2009 | Whirlpool Washing Machines
I hear some different noice along with slight vibration, when water filling in the washing machine. my washing machine model is Whirlpool F65 fully automatic one 2 one 2 wash. Its need any service?
Could the sound be described as a chatter / rapid clicking?
If so, it's probably the inlet valve for either the hot or cold water which is not opening all the way due to a dirty/malfunctioning solenoid valve.
Charlie
Aug 14, 2009 | Whirlpool Washing Machines
Jan 01, 2009 | Washing Machines
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
