Question about Mitsubishi WS-65611 65" Rear Projection Television
I have a 65611 Big Screen TV. The TV shut itself off. Pressed the reset button, It flashes green then off. Pressed power again and it just shuts off. Unplugged the tv and replugged. Have a power strip and backup battery/strip. Still shuts off
  • 57 Answers
Hello it looks like you a problem with your main board, maybe a horizanal deflection. you can get the problem by run troubleshoot codes, first hold the buttons mune and input or device until starts blinking account the blinks, it will blink few times and the it will pause for a second again will blink. get blinking number like, 2 the 2, or 2 then3. that means 22 or 23. 22 means convergance problems. feel free to call me if you need more help with your tv. 602-810-7149 i live in mesa az
Posted on Dec 31, 2010
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
Resetting lamp life
was the button sequence given (set off) display,5, volume up, then power?
Mar 21, 2012 | Sony Grand WEGA KDF-55XS955 55" Rear...
Olevia TV shut off by itself.
You probably have either loose solder joints or components that failed after heats up. You need to look inside to see. Learn more about failed TV and monitors, caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Televison & Video
MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv won't turn on or respond
if its a sony bravio LCD the backlight inverter failed
Dec 06, 2008 | Televison & Video
Problems after power outage
I figured out I could still get the TV Menu so I pressed that and then I pressed 123 and it did a TV reset and then it was working again.
Aug 05, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WS-65611 power and volume problems
when it shuts down Try pushing the input and menu buttons together on the set it self and hold them both in for 8 seconds.and see if the LED blinks a diagnostic code.
Mar 29, 2008 | Mitsubishi WS-65611 65" Rear Projection...
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Mitsubishi WS-65611 65" Rear Projection Television Logo
181 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
