Question about Mitsubishi WD-73827 73" HDTV DLP TV
I have a dlp tv and something got sprayed on it and theres a large spot on it what can i do to fix it
  • 57 Answers
Ii the mark is stain it into the screen more like it you to replace the screen, but first use soap and water, if goes away good,if dont replace it. if need more help feel free to call me 602-810-7149
Posted on Dec 31, 2010
How do I remove vertical lines from my Mitsubishi 65 inch DLP?
it is your dlp chip i just changed mine make sure it is in tight ther is a video on you tube that is very helpful mine did the same thing with the lines untill i got the dlp chip in tight
Jan 17, 2013 | Mitsubishi WD-65735 Television
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
We have a Samsung 50"
U have a air compressor machine?Take ur tv back cover off,blown compress air into it the screen compartment,will work the best.Unplug the tv like a day before for it to used Smoke bug-bomb,but the spiders could died inside though,that the problems.After 2-3 hrs replug the tv should work with no problems.
Jun 12, 2011 | Samsung 50" Slim-Depth DLP HDTV
TINY WHITE SPOTS ARE APPEARING ON THE SCREEN OF MY SAMSUNG DLP TV, IS THERE ANYWAY TO FIX THIS PROBLEM?
The DLP chip is failing and will have to be replaced, very expensive. You can call samsung at 1-800-samsung to find the closest service center.
Jun 08, 2011 | Samsung DLP HL-P5663W 56" TV
I have a 67" DLP TV and last night 2 white spots
That usually indicates that the optical block is going bad. That repair is usually 900-1100 dollar fix.
Mar 30, 2011 | Samsung HL-67A510 67" DLP HDTV
Black spot in bottom of tv
I just had my caps replaced and after the tech put it back together there was a spot. He tok the screen off and cleaned the mirrors around the bulb and the large mirrors(they were reaaaalllllly dirty. It did brighten up the picture and it looks crisper, oh and the spot was gone.
P.S.. Like nettiser stated. If it's unde warrenty have them do it. If you drop something "you will be pissed" if you don't !
Aug 10, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Samsung DLP white spots
Are the spots fixed or do they move with the image? Verify that all venting is clean of dust. If the spots are fixed and upon close examination are a square shape, The device is overheating of failing. If the spots are moving with image it's a front end problem, and can be overheating as well.
Jun 27, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots on screen and growing every day
If these spots are small, they are likely the visual effect of a failing DLP chip. When some of the tiny mirrored surfaces on the chip stop moving, this is the result. This is not something you can fix yourself. A Samsung authorized service center will charge $400-$500 to replace it for you.
michtech
Feb 18, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Numerous white spots on Smasung DLP TV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Toshiba dlp
Sound like you light engine is going bad. A major problem to fix! Especially if you are sure it is a dlp
Jan 07, 2008 | Televison & Video
Mitsubishi WD-73827 73" HDTV DLP TV Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
