Question about RCA R52WM24 52" HDTV Projection Television
Rca r52wm24 the tv has double vision and shadows , then goes black screen. I unplug it for 10 - 20 min . screen still distorted
  • 57 Answers
HELLO AM RICO, I WORK ON TVS SOMETIMES. ON THIS MODEL OF TV ITS COMMON FOR COLD SOLDER AROUND THE FLYBACK, CHECK THE FLYBACK, IF THERE IS COLD SOLDER AROUND THE FLYBACK. YOU NEED TO RESOLDER THE FLYBACK AND REPLACE A 5 AMP PICO FUSE. IF YOU NEED MORE HELP PLEASE FEEL FREE TO CALL ME AT 602-810-7149 I LIVE IN MESA AZ
Posted on Dec 31, 2010
The tv has double vision and shadows
It is the convergence module that needs change, that is what is causing the red green and blue to be out of alignment. You need to change the module.
Nov 03, 2010 | RCA R52WM24 52" HDTV Projection Television
Color distortion
You will need to install the RCA repair kit called ITC222 & ITC222A convergence option missing repair kit. Its available from www.tvrepairworld.com and it contains the parts and the CD with instructions.
Jul 14, 2010 | RCA R52WM24 52" HDTV Projection Television
The screen is almost a double vision panorama. Please advise.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | RCA R52WM24 52" HDTV Projection Television
Tv shows double vision and the colors are off
There are bad solder connections on the flyback transformer and there is a fuse opened up. Probably can't fix this yourself unless you have some experience.
May 11, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA HDTV
go into the menu
looking for set up tab
looking for convergence tab
looking for automatic convergence. apply.
Fixed. NO? tv has a problem in the convergence area. Technican Job
Apr 08, 2009 | RCA R52WM24 52" HDTV Projection Television
DOUBLE VISION AT TOP OF MY SCREEN. DISTORTION.
Good Day, wars;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Sep 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Double vision pretty much
This problem from what you are describing is a convergence issue the customer menu has a option that might help set convergence. if that doesent work a technician may have be called to adjust convergence or see what part has failed in the convergence cuicit
Feb 18, 2008 | RCA R52WM24 52" HDTV Projection Television
Double vision and no convergence
I have found that fusible link FL231 is the main cause of this problem. It's located by the high voltage transformer and looks like a square coil.
Check it with an ohm meter and if it checks bad, then, replace it and you should not have to realign the convergence.
Any questions or comments, respond to this post and I will reply.
Jan 01, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
131 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
