Question about Garden
Are fuel tanks for mitsubishi TM 24 brushcutter engines still available?
4 Suggested Answers
vincob
  • 718 Answers
SOURCE: Have a fs88 brushcutter. Had
Take it back to your stihl supplier they should back up there work.
Posted on Mar 10, 2011
If your brushcutter does not run or rev, clean out the exhaust, some of them have a small mesh baffle which needs to be kept clean. If it clogs up just sit down for aawhile with a very sharp neddle or something similar and unclog the little holes, this is a better option than buying a nes one.
Posted on Jan 23, 2012
Hobbit_who
  • 2044 Answers
SOURCE: I am after a manual for a Kubota D210 Brushcutter
his one is the closest I can find but will answer your questions
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi_outdoor/bc30_zr30004_ss30_zr30002_cs30_zr30000.html
Posted on Apr 09, 2013
Ryobi brushcutter runs good on full tank gas but at a half a tank it starts spitting and sputtering...why
CK for split fuel lines. You can ck when fuel is low by trying to prime with bulb, if you see air bubbles in line , split line in tank.
May 03, 2014 | Cars & Trucks
6g74 engine montero 2001
the fuel pump is electrical high pressure pump and is located either next to the fuel tank or inside the fuel tank depending on the exact model the pump is cylindrical and if outside the tank will have wiring connector running to it
Jan 14, 2014 | 1998 Mitsubishi 3000GT
Honda gx25 brushcutter
should of had the carb adjusted first
Oct 06, 2013 | Garden
STIHL BRUSHCUTTER VERY HARD TO STARTAND WON
Could be a fueling issue, check fuel lined and fuel tank vent. Vents can become damaged and create a vaccum in the fuel tank, stopping the carb from drawing up fuel from the tank.
Jun 07, 2012 | Stihl String Trimmer Brushcutter Service...
The fuel line on the homelite brushcutter mightly light have degraded and split, can I change them and if yes, how, or do I have to buy a new petrol tank?
Yes, its a do-it-yourself deal. They have fuel line kits at Home Depot and at the small engine shops. They use what they call "tygon" lines now. Remove old lines. One of them should have an in-tank fuel filter on the end. You can use needle nose pliars or even twezers to reach into the tank to grab. The fuel lines themselves seal the holes in the tank. No sealant is used. Cut new lines long and angle cut an end. Start that cut end thru the hole in the fuel tank and push it in slowly until there is enough to grab. Cut filter line lone enough so that it will move around on far side of tank, then put fuel filter on its end. The other line you shove into the tank will be pulled back thru and cut to a length aboutm 1/2" or so...it should have some type of little nylon connector on its fuel tank end to hold it in the tank . Good luck. Please vote on this solution.
Sep 03, 2010 | Homelite Mighty Lite Lawn Trimmer
Where is the fuel filter on a 2000 mitsubishi galant
Your vehicle does not have a serviceable fuel filter. The 4 cylinder and 6 cylinder engines that are available in this vehicle have either a fuel pump module or a strainer,both of which are installed inside the tank with the fuel pump assembly. I would not worry about changing or trying to replace these parts unless it is absolutely necessary,and if this is the case, then it would be a great idea to replace the entire fuel pump assembly while you have it removed from the fuel tank.
Jun 10, 2010 | 2000 Mitsubishi Galant
Where is the fuel filter in my mitsubishi galant 2000?
It is either inline or on fuel pump inside fuel tank. Follow lines from fuel tank to engine to locate filter,if not it is in fuel tank on fuel pump.
Jul 05, 2009 | 2000 Mitsubishi Galant
Fuel tank
www.denniskirk.com
Apr 26, 2009 | 2008 TM Racing EN 530 F e.s.
Garden Logo
288 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
