Question about Video Game Consoles & Games
Hi yes have a xbox 360 and each time i try to log on my page it would not let me connect and its keep saying some xbox 360 features are missing or corrupt. then it says a system update is required to replace them. your console will now restart. and it also says that if the problem persists, there may be a problem with your storage device.
  • 85 Answers
SOURCE: storage device not found
Saving a game requires you to have a Hard drive or memory card did you purchase the premium edition xbox 360? you can look on the outside of the xbox 360 box it will give the specs and what came with the system. If the hard drive is not on the list then you will need to buy one the xbox doesn't come with any internal memory like the systems in the past have. you will need to purchase a HD or a memory card. If you have the premium edition let me know ill instruct on how to set it up.
Posted on Dec 27, 2007
  • 10 Answers
SOURCE: xbox 360 update problems
If the above suggestion does not work, which i think should, try to delete cache on Xbox 360 console. Firstly, go to System tab, then go to Memory, then, highlight HDD (DONT CLICK) and press Y. Enter x, x, left bumper, right bumper, x and x . Sorry, but this does not always work, if it dows, when the tab appears that asks if you want to perform maintenance, click yes
Posted on Aug 09, 2007
  • 18 Answers
SOURCE: xbox 360 console
If you are speaking of refurbishing the DVD drive, this site has the information you need. NOTE: I would assume this would void your warranty, do so at your own risk: http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm Go to the area entitled: Refurbishing the Xbox 360 DVD Drive
Posted on Aug 20, 2007
SOURCE: 360 drive only reads dvds, not xbox 360 games, just says put in an xbox 360 console.
how do i flash drive
Posted on Mar 02, 2008
bobntina
  • 29 Answers
SOURCE: Corrupted profile on XBox 360
E68 is a voltage error. That means that the Xbox has insufficient power to function properly. This can be caused by an error in the hard drive, the internal cooling fans or the main board using too much power. it can also be caused if you have attached an external cooling unit. Unplug the hard drive and any other external hardware then try to power on again to see if you get the same message. Check your power supply to make sure the light is green when you power up. If it is not green it is a power supply issue, make sure it is plugged directly into the wall, no extension cords or power supplies. If you do that and it is still red change the power supply. If the light is green and you still have the issue contact microsoft. If you are under warranty they will fix it for free and if not they will fix it for generally 99.00. You lost your profile due to the power issue. Your profile is saved on flash memory and the power issue probably corrupted the memory. Fix the power issue then reset to factory default and you should be good.
Best,
Bob
Posted on May 12, 2008
I'm losing my connection...
It sounds like you've refused an Xbox Live Update at some point.
You can go into your system options and see if there's an update available.
To check for an update on the Xbox 360 you basically force a new Xbox Live connection:
  1. Press the Guide button (center logo button), bringing up the pop-up menu
  2. Go to Settings
  3. Select System Settings
  4. Select Network Settings
  5. Select Wired Network or the name of your wireless network if you're on wifi
  6. Select Test Xbox Live Connection
  7. Select Yes if prompted to update. If you're not prompted and the test completes successfully, you have the most recent update.
If that doesn't work try this link http://www.gamefaqs.com/boards/927749-xbox-360/67807343
Jan 08, 2017 | The Video Game Consoles & Games
My xbox doesnt want to pickup the ethernet connection
There are two ways in which you can address this issue:
1) Attempt to connect wirelessly. You can access this feature via "Settings" on your XBox home page. After setting up your XBox to automatically connect to your internet router (by entering the password and name), you should be able to log into and play on XBox Live.
2) Connect via ethernet cable.
Although you've already tried this, it's possible there is an issue with your modem and not your XBox. Routers and modems usually have a shelf life of about 2-3 years-- if you have had yours for longer than that, it might be time to invest in a new one. Another issue could be a faulty ethernet cable-- they're usually pretty cheap (around ten bucks), so if the above fixes don't work go into a local electronics store, purchase one, try it out, and if it doesn't work return it immediately and you should get your money back.
Jan 31, 2012 | Microsoft Xbox 360 Console
Wireless adaptor was working fine until xbox live update, and since the update is unable to pick up our wireless netowork. Tried switching everything back on and on and re synching modem with xbox, to no...
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
  1. Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
  2. Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
  3. Connect the wireless adapter cable to your Xbox 360 I/O port.
  4. Flip up the network adapter's antenna.
  5. Turn on your Xbox 360.
    • If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
    • If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
  6. On the Network Settings page, select Edit Settings.
  7. On the Edit Settings page, select your wireless settings on the Basic Settings tab.
  8. On the Select Wireless Network page, select your wireless network.
  9. On the WEP Network page, type your wireless network key, and then click Done.
  10. On the Apply Settings page, click Test Xbox Live.
  11. If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
  1. From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
  4. Wait for the router to reboot.
Dec 20, 2010 | NetGear MA101 802.11b Wireless Adapter
I try to log on but is says that i need an update but i can't my connections is bad and it keeps saying to check my connections
The newest update for Xbox 360 for the launch of Kinect is causing problems. I fixed mine by going into System Settings, Network settings, then running a test on xbox live. Initiating the test logs your profile out then runs a network test. The test completed with no problems and then asked me if I wanted to update again. Without logging back into my profile I clicked OK and the update ran without a hitch. I think the solution lies in the fact that my profile was logged out and from what I have seen, the only way to connect to xbox live without a profile being logged in is with a network test. Once you connect to xbox live it senses that you don't have the update and asks you again, this time without a profile logged in and you are able to do it.
Nov 01, 2010 | Microsoft Xbox 360 Console
Hi can u help me please i'm trying to connect my xbox 360 to play online but i've got a problem....... it says network connected internet connected xbox live failed
Hi loads of people are having the same problem, xbox live must be having some downtime or server issues if you was the only one then it could be your end but in the last hour their have been loads of posts regarding this problem and all users are getting the same message.
try switching you xbox off and back on and if it still dont connect then your going to have to wait i would try again in an hour or two, usually down time for the servers is a couple of hours while xbox install updates to xbox live, its not a problem your end so dont get changing any settings, the problem is with xbox live so just bare with them and it will sort itself out.
the last time this happened was about 6months ago and the downtime was just over 4 hours, so bare with them for a bit and it will be sorted.
you could try logging into the xbox site on the net and not through your xbox and check the xbox chat rooms and you will be able to find out more their.
let me know if you need further assistance ok
plz rate this solution as i have a whole page on unrated posts, thanks
Aug 31, 2010 | NetGear Computers & Internet
Could you tell me in steps how to conect to xbox live
Step 1 Form your Xbox 360 you need to be connected to the Internet by a straight LAN line or wirelessly. You can test you connection by going to the setting screen on your Xbox 360.
  • Step 2 Once connected to the Internet for your Xbox 360 go to your main account screen and find the tab that says "Join Xbox LIVE" click on that link then follow the simple instructions that the Xbox LIVE will provide. At this point you should have a name in mind for your gamer tag.
  • Step 3 Xbox 360 LIVE has several different options available for memberships. They are a monthly, 3-month and 12-month membership accounts. I would recommend a simple one month account if you just wanted to check out the features offered on XBOX 360 LIVE. If your an avid gamer and love to play games online with friends, the 12-month Gold membership is the way to go.
  • Step 4 Once you've completed the process of joining Xbox 360 LIVE, they will send you a confirmation email confirming your membership. Now you can log on to Xbox 360 LIVE and start doing this like customizing your avatar and playing online multi-player games.
  • May 26, 2010 | Microsoft Xbox 360 Elite Console - Black
    Hello i have problem, i install my ffxi to HDD xbox360
    Hi! Basically, not all Xbox 360 games are support by this "install" feature. This install feature has started around mid 2009 and thus games developed during that time and so on were theonly games capable of being installed into the Xbox 360 Console's harddrive.
    May 06, 2010 | Microsoft Xbox 360 Console
    EA Sports server issues
    yes they are talking about on xbox live for online play. put it this way the ea servers are like an engine that hasnt been run for 30 years. they are all gumed up and broke down. they probably are planing a new ea game and dont have enough memory for online play for all the games
    Jun 24, 2009 | EA - Electronic Arts Tiger Woods PGA Tour...
    Xbox games
    Try This Hacked Firmware for the 360
    What you need
    - A PC
    - Xbins Downloader 2008 (HQ Downloads)
    - Winzip
    Let's Get Started
    1. Ok first download and install "auto_xbins_2008.zip" which I have uploaded it here on HQ for your convenience.
    2. Unzip the auto_xbins_2008.zip file to your computer and start the program.
    3. When you start the Xbins Downloader 2008 program, it logs you on the IRC server and takes you to the correct location all by itself.
    4. When logged in you will see 2 folders in the right hand window, one (1) for Xbox(original) and one (1) for the Xbox 360.
    5. Go to the 360 folder, from there you will see all the sub folders listing all the other types of files including firmware. Yes the latest ixtreme is in there.
    Warning (DO NOT BE GREEDY OF YOU WILL GET BANNED) get 1 file at a time, and if you get warned leave and come back after 24 hours and go again. (Speeking from experience here).
    Just drag the file from the right to the left window.
    This tut is for all those that think this info is out of your reach IT IS NOT and for those who want to keep these files and locations Hush, Hush and make money from free info, and for those who hate torrents as I do.
    For help on installing the files go to the HQ VIP forums here and yes become a VIP Member it helps to keep this community alive and helps pay for the site fees. (They are not free)
    360-HQ Forums: here
    Nov 20, 2008 | Microsoft Xbox 360 Elite Console
    IP address Problem when connecting to xbox 360 live
    i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
    Sep 26, 2007 | Microsoft Xbox 360 Console
    Video Game Consoles & Games Logo
    204 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
