Question about Dishwashers
Water not pumping out of LG model no.LD1415T1 dishwasher pump blocked or faulty how can I fix it? thanks,Gaz
  • 472 Answers
Well gaz put your work clothes on i am a lg oem authorized repair company... if the pump is bad you have to pull the dishwasher and turn it up to get to the bottom of unit and replace... not really that difficult just time consuming... it is possible to get down into it from the inside of unit by removing componets in bottom of dishwasher and checkwith your finger for obstructions...these things have plastic impellers so it doesnt take much to take out the motor... goodluck.....
Posted on Dec 31, 2010
My LG LD1415T1 dishwasher displays E1 at the end of short wash cycle. It's OK again when cooled down
from what I can work out this is related to measurement of the flow and water levels, check all hoses etc for any build up and make sure they are clean.
http://answers.lg.com/answers/7676/product/MD00000191/lg-electronics-ldf6920st-questions-answers/questions.htm
Feb 05, 2015 | LG Dishwashers
Siemens Dishwasher Fault
there is a water level sensor in the bottom of the machine if this is faulty and stays on, this will indicate to the pump there is water still in the machine. I would check this sensor it might be blocked with debris and has blocked in the closed position. that woudl be the best start for this issue.
i hope this was useful.
Feb 15, 2013 | Dishwashers
So frustrated - LG dishwasher washes 5 minutes then shows OE code - have cleaned drains, sump pump, out let pipes. Still doing it. ONly 9 months old..... My old dishwasher worked for 10 years.......
Hi there Diane OE on your display relates to the water draining system (water is not pumped away). the diashwasher is not seeing the water drain away. Dishwashers start by draining before they take on fresh water. Start your dishwasher and listen for a pumping noise from the waste pump if you dont hear any noise it may be the pump is blocked or faulty. please advise if this helps kind regards gary.
Nov 08, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
LG Dishwasher - LD1415T1 - ERROR CODE: OE. Ive cleared the filters and still not working?
"OE" indicates outlet error in your dishwasher. Check that you can hear water pumping first if not check your drain lines for obstruction.
Thank you !!
Jul 30, 2010 | Dishwashers
Have a LG dishwasher with a OE error. Took machine ouside and it works well with the garden tap hooked to it. Put it back inside and does not work. I noticed a major kink in the inlet hose, would this be...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Im receiving an OE error code on my LG Dishwasher Model LDF7811st. The machine runs for a little bit and then it dings a few times with the "OE" code and stops running. HELP please
Apr 21, 2010 | LG 24 in. LDF 7811 Stainless Steel...
My Lg Dishwasher , model 12aw2 , has an error message OE shortly after start up , dishwasher is over 6 years old , is this a simple fault to repair? or not worth it ?
Feb 11, 2010 | LG 24 in. LD-12BW5 Free-standing...
Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Aug 15, 2009 | LG Dishwashers
LG DISHWASHER WORKS BUT VERY NOISY MODLE:LD-2040WH
The main water pump on this model does not last long. The water seal between pump and motor starts to leak that result in the adjacent motor bearing corroding and eventually failing, resulting in excessive noise. Later the water leak becomes so bad that it triggers the "E I" water leakage display and prevents it from completing the program. The pump and motor is sold as one unit and the whole unit must be replaced. I have tried to replace the faulty bearing and repacked the rubber seal with silicon grease but with no success. If anyone have repaired the water seal successfully please let us know.
Jun 15, 2008 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
189 people viewed this question
Top Dishwashers Experts
Owen Barnes
