Question about Black & Decker 18V Cordless Drill/Driver
I have a Black and Decker 18 V drill .I opened the bit up to its largest opening and now cannot get it to budge. It is a keyless chuck. thanks, RW The model# iis CD180GS
  • 784 Answers
I have had that same issue -- I just get a pair of channel locks and clamp onto the chuck ( not hard ) and run the drill forward -- this should close the teeth.
c...
Posted on Dec 31, 2010
Black and decker 20 volt keyless chuck stuck open how to freeit
two pairs of multigrips
one on e chuck and the other on the bit that does the turning to tighten on the drill bit.
Apr 19, 2015 | Drills
Keyless chuck overtightened
two strap wrenches work well becasue they will not crush or scratch the chuck like channel locks or any plier.
Apr 04, 2014 | Black & Decker Black and Decker FIRESTORM...
My black and decker 12v drill is 'locked". The area where you put the drill bits in won't loosen or tighten so it won't hold any bits. I have tried to manually loosen or tighten it too but nothing...
Try shooting some WD-40 lubricant into the 'chuck' and let it sit for awhile, then rotate the outer part of the chuck CCW to loosen the 'jaws'. If the chuck is a keyless type, just hold the chuck and turn the reversing switch to 'reverse', then gently apply power to the trigger--that should open the chuck jaws. You will likely find that a leather glove on the hand holding the chuck will help prevent a burned hand if you lose your grip. If it is a keyed--type chuck (there will be ring of gear teeth on the front edge of the chuck), then a key with a small gear near one end is required to turn the chuck open (turn the key CCW). Hope this helps!
Jan 25, 2011 | Garden
How do I exchange bits in the keyless * BLACK & DECKER 12-Volt 3/8" Cordless Drill
In Black and Decker drills when the drill stops turning the chuck spindle locks automatically. All you have to do is grip the outer sleeve of the chuck and turn it anti clockwise to open it. Turn it clockwise to close it. When you press the trigger to start drilling the spindle unlocks automatically again.
Jan 10, 2011 | Black & Decker Garden
I have a Black & Decker 18V cordless drill with keyless chuck. The spot where the drill bit fits is in the open position stuck and won't turn in either position. What am I missing how to unlock it?
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Jun 12, 2010 | Black & Decker CD9602SB 9.6 Volt Cordless...
Keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Feb 23, 2010 | Garden
Black decker drill keyless chuck won.t open !
hold the back of the chuck with channel locks or a vice and use the same channel locks on the front and open the chuck manually it should work and you can get to the screw to replace it or the hand chuck. this can be a little frustrating but hang in there and you'll be a pro shortly.
Sep 02, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Aug 18, 2009 | Black & Decker Drills
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
Black & Decker 18V Cordless Drill/Driver Logo
658 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
