Question about Dell 922 All-In-One InkJet Printer
Left Cartidge incorrect
When I turn my printer on the error message that comes up is "Left Cartridge incorrect". I have taken it out and put it back in a number of times, but at no time has it looked wrong or even uncomfortable. I haven't bought a new ink cartridge for quite a while yet it still reads as having plenty of ink left. I don't know what to believe.
  • nikeowl Jul 22, 2008
    Funnily enough, I bought a cartridge in the end, now the problem has changed. The supplier, though I didn't know it at the time, supply refilled cartridges and in this particular printer the effect is particularly bad. It reads that the ink level is below the advised level. I know it is terrible saying this and now every time I try to print it prints out black and blue boxes and freezes the computer. It's ridiculous, Dell is the worst of all computer manufacturers that I have yet come across. I apologise, but it gets me.
    Scholar:
  • 41 Answers
Hi, remvoe the black ink cartridge , dip the cartridge in luke warm water for 30 secs , clean the cartridge and unplug the power adapter from the printer , wait for a minute and then reconnect it back , put back the cartridge and then look for the error msg , if it stil displays the same error then its an issue with the cartridge and needs to be replaced..
Do lemme know if it helps..
Thanks
Posted on Jul 12, 2008
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't...
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Jul 24, 2011 | Lexmark X4650 InkJet Printer
I get error meesage 1102 on my Dell 944 printer. it's telling me cartidge error or incorrect cartridge. i have used only Dell cartridges and have not changed recently. the cartridges are not empty. can...
Turn off the printer and unplug the power cord for about a minute. This should reset the error codes. If you still receive the same code when you go to print, open the case and the cartridges should move to the center to be replaced. Take each cartridge out and make sure there is nothing that is covering the sensors or physically wrong with them. Put the cartriges back in and make sure they are "seated" properly. Test to see if you still receive the error message.
If you still experience the error message and the cartridges are old or less than 50% ink, there might be an issue with the cartridge's internal sensor. You can find out more information on the internal sensor's HERE
Dec 14, 2009 | Dell Office Equipment & Supplies
Replaced black cartridge in my lexmark 3500-4500 printer. message reads "left cartridge incorrect". Have taken cartridge out and put back in numerous times still get this message.
You may have bent or broken a sensor wire. Check how the other (color) side looks by removing cartridge and confirm that nothing is awry. Otherwise, clean the metal contacts on both printer (power off and unplug) and cartridge with rubbing alchohol and a cotton swab, then try again.
Aug 18, 2009 | Office Equipment & Supplies
Lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Jun 13, 2009 | Lexmark X9350 All-In-One InkJet Printer
Newly installed Cartridge. Problem: "Left cartridge incorrect".
When you place the old cartidge does it give you this problem.try to clean the contacts on the printer and the cartridge it self.
May 03, 2009 | Lexmark All-in-One Printer with PictBridge
No cartridge error message after power-on
plz follow some step:-
1. try to reinstall cartideg and check.
2. check printer with new cartirdeg or check your printer cartidge in any other printer .
your cartidge may by faulty 90%
3.now the problem in your printer sencer so do service of your printer if u can.
thanks
Apr 29, 2009 | Lexmark X342n All-In-One Laser Printer
HP 3650 gives incorrect error message
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | HP DeskJet 3650 InkJet Printer
OKI C3200N laser printer, low toner problems
For each toner there is an individual toner sensor. There is a real good possibility that the metal contacts on the sensors have become dirty. Typically, a little bit of canned air directly on the sensor contacts will resolve the issue.
After removing a toner cartidge, look to hte left side of where that cartridge rests. The sensor is located there.
May 05, 2008 | OKI C3200n Led Printer
Lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
Oct 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Print Cartridge Missing
had cartridge refilled put back but comes up no cartridge
May 21, 2007 | Lexmark Optra S 2450 Laser Printer
Dell 922 All-In-One InkJet Printer Logo
378 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
