Question about Nintendo Wii Console
Recently got a Sharp HD tv and trying to connect the wii to it... the wii picture only comes up in black/white? how can this be fixed.
  • 492 Answers
Apparently the settings on your Wii are set to be displayed in PAL (Japan), where your TV is trying to output it as NTSC, hence they are conflicting. Check the settings in your Wii and change it to NTSC to see if that corrects your problem. I would also check the connection for your AV Cables or Component Cables, they may be loose or plugged in improperly.
Posted on Dec 31, 2010
Wii in black and white
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
I previously had my wii on an older tv and it worked fine. I recently purchased a new tv (Sharp Quatron Aquos) and when I hooked up my wii and same cables to the tv, my screen is now a hazy black and white...
You are using composite cables(red,white,yellow) mine did the same thing. The aquos is all digital, wont read analog, which is what composite cables are.
They now make a component cable for the wii. I paid $28 at b.b.
Mar 12, 2011 | Nintendo Wii Console
Hello, when I connect my Wii to a Samsung 3D plasma tv I get a black and white (non-crisp) picture but I do get sound. When I do the same set up on a tube tv everything works. I tried the set up on...
a 3D tv is another form of an HD TV, you need the Wii HD cable to play it right, and make sure you plug it into the HD ports on the TV to get the color and sound back.
Sep 12, 2010 | Nintendo Wii Console
When I try to hook up my nintendo wii to an hdtv I get a black and white picture? The RCA cable only has 3 cables and the input on the tv has 5 outlets.. could this be the reason? how can I get it to work?
The RCA cable you are using is meant for standard resolution TV's. There should be a spot on the HD TV for the standard RCA cable. This will resolve the black and white color issue but unfortunately you will not get the benefits of your HD TV. Your best be is to get a composite cable for the Wii. You can get the cable from target or wall-mart but online shopping will typically result in a cheaper price.
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 26, 2010 | Nintendo Wii Console
I just hooked my wii & all we get is black & white
I had the same problem. Instead of going directly into the TV, I tried plugging the component cable into the auxiliary jack in my digital cable box and that seemed to fix it. Works great now.
Jul 19, 2010 | Nintendo Wii Console
Tried to hook up to a AKAI Plasma TV...Only get black and white grainy picture
Ok this is a quick fix. All you ned to get a set of Wii HD cables from the store and all should be fine. Also you might not want to put your Wii on a Plasma TV its not good for the TV try using on LCD, LED, or plain old tv works best that way no image burn
Jan 03, 2010 | Nintendo Wii Console
I just bought a new plasma tv. I cannot seem to
You Plasma TV is probably an HDTV, which means you need to change the settings on your Wii to HD. Just go to the Wii menu and modify the TV settings. If you don't want to do that, make sure you connect your RCA cables to the non-HD slots on your TV so that the yellow RCA cable is in the yellow slot and not the green HD slot.
Dec 17, 2009 | Nintendo Wii Console
Plug in the wii system and everything comes in black and white
Try plugging it into another scart socket, this sometimes happens when a tv does not support 60hz. the result is a screen that has no colour. You could try just plugging it onto the seperate av inputs. Most tv's these days have one scart that will work ok and in colour.
Jan 18, 2009 | Nintendo Wii Console
Wii Black Screen
i put the wii on, powers up but i get a total black screen. wiimote does not connect either. what can i do to resolve this?
i have already disconnected all wires and connections, left it off for hours and tried putting it on again. no change. Black screen still remains. HELPPPP
Dec 01, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
93 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
