Question about Frigidaire Affinity ATF7000E Front Load Washer
Was washing a load of clothes and once it filled up with water i am getting a dr flashing message. The door will close but it will not lock so i cant finish washing my clothes
  • 472 Answers
If it still has water in it.... most likely you either have a obstruction in the clean out located front bottom of unit behind panel or the drain pump itself has failed.... the code is drain... it gets to its first rinse cycle the wont drain therefore will throw codes on you.... good luck service 18 years a/c and heating unlimited texas
Posted on Dec 31, 2010
Zanussi Washer Dryer wont wash!
Sounds like the switch that tells the controller that the door is closed and locked is actually bad or the plastic molded part holding the switch is broken. Inspect the interface for cracks.
Nov 22, 2014 | Zanussi Washing Machines
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Washer will not start. Getting "dr" message . Door lock light is not lit. Tried cancel and restart tried unplug and restart still getting dr message
    The 'dr' error code stands for 'door switch is not closed'. If the door is closed properly, then you will have to replace the door switch assebly.
    Hope this helps!
    Jun 25, 2010 | Washing Machines
    Have a AML 125 front loader which is flashing three lights at us: The lock light flashing very fast plus Rapid and 1200-600 lights flashing. When we power up and close the door it starts doing this and...
    Top 10 frontload washer problems
    1)Water fill problem: water took more than 10 minutes to fill to desired level sometimes indicated as a LF/IE or long fill/inlet error. Water valve screens clogged, hoses kinked, low water pressure, unpaid water bill. Check hose, clean screens.
    2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunnion. no error code
    3)Dispenser drawer open/detergent in wrong compartment: washer will not operate with drawer open or cleaning products in wrong compartment.
    4)Washer won't drain: clogged pump/filter, slow or clogged drain usually indicated as a LD/DE, if a code is given (long drain/drain error) Clear pump of objects
    5)Drum overfilled: usually caused by sediment in the water level pressure sensing tube going up to the main control.Find it and blow out the sediment, re-secure pump out water and retry.
    6)Door open, Door not latched, clothes/objects keeping door from completely closing. Tighten door latch, add washers if nessisary to make good contact and close door tighter in case of leaks.Note some models send a signal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
    7)Cold water does not enter washer: hoses connected backwards. Oops.
    8)Oversudsing: Wrong Detergent, too much detergent, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
    9)Locked motor: error LE,loose connection,broken wire/hallsensor, motor overheated/failed.
    10)Water heating error, hE, the thermister/heater is out.
    Feb 13, 2010 | Ariston Technologies Washing Machines
    My washing machine gets stuck when it is going to start the rinse cycle
    2)Excessive vibration: noisey,roar, knocking noises. Bad damper,bearing or broken trunion. no error code
    6)Door open, Door not latched, clothes/objects keeping door from completly closing. Tighten door latch, add washers if nessesary to make good contact and close door tighter in case of leaks.Note some models send a sig nal to the motor and another to the control letting both know the door is secure before proceeding, corrosion gets into the lid lock and the door can be locked and the control is ready but the motor ain't getting the message.
    8)Oversudsing: Wrong Detergent, too much detergen, detergent in wrong dispensing drawer, turbidity monitors pick up particles in the water and judge soil content then the washer allows for extra time to wash the clothes, if the wrong detergent is in there the machine thinks that is too much and declares a suds error. On some models a suds detect is determined by the motor over amping, most machines will try a few mini loads to correct the problem. Remove detergent, retry
    10)Water heating error, hE, the termister/heater is out.
    Your repair Manual with photos and tech data HERE
    I will leave that on there for a while but it takes up broadband so print that manual out and keep it close to that washer.
    Feb 10, 2010 | LG WM-2277HW Front Load Washer
    Machine will not fill the door locked sign
    Sounds like could be fill solonoid valve faulty or water turned off..
    Jan 23, 2010 | Hotpoint WMA54 Front Load Washer
    I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
    dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
    Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
    Front loading ge washing machine only 2 months old. door locks,
    take water lines off of water valve at rear of unit and clean dirt out of screens.
    Jun 19, 2009 | GE WSXH208A Front Load Washer
    Frigidaire Affinity/dr error
    dr code means door not closed
    get some crc spray and spray into lock on machine
    that will lube the workings and should fix problem
    Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
    Frigidaire Affinity ATF7000E Front Load Washer Logo
    73 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
