Question about Belkin (F5D7230-4) Router (587009)
I need an IP address for my belkin router - Belkin (F5D7230-4) Router (587009)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 143 Answers
The default Ip address for your routers web interface is 192.168.2.1
Posted on Dec 31, 2010
Im trying to set this up as an access point. but it will not fine a ip from the router
Most router wont act as a DHCP client (Get an IP address) on their own.
You need to go into the Belkin setup and set it to an IP address in the range of your other router.
For example:
If your PC is getting (connected to the same network) an IP address of 192.168.0.3 IP and a Default Gateway address of 192.168.0.1 you can set the Belkin with any adderss between 192.168.0.10 & 192.168.0.254. Changing the last octet (set of numbers after the 3rd period) to the desired address.
Mar 02, 2011 | Belkin Wireless-N Wireless Router with...
How can I get my IP address set for my Belkin router... IP # 192.168.2.1 ???
Hi go to http://whatismyipaddress.com as soon as the page loads you will see your ip address and if you need other ip details just click the gray box beside the ip address it will be labeled additional ip details you will see things you didn't expect!! hope this helps
Feb 02, 2011 | Belkin Basic Wireless Router
Is there any case that the port from belkin router
This may happen due to double NAT issue.... the DSL modem might give an IP address in the range of belkin route....that is 192.168.2.X check for the ip address when the computer is directly connected to the DSL modem... now check for the IP adress when the Belkin alone is connected to the computer.... if they both give an IP adress like this 192.168.2.X......(X can be any value) then you will face the above issue..... in that case you can login to router and change the IP address of belkin router from 192.168.2.X to 192.168.15.X this will resolve the issue
Apr 15, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin N router and linksys ip cam
You need to connect the camera directly to your computer and have it manually assign an IP Address on your computer so you could access the camera on the first hand.After that you need to range the IP Address of the camera accordingly to the IP Address of your network.
May 05, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin DI-604 router connection problem
Change the router's IP address to 192.168.10.1, The Qwest modem like Action Tech have the same IP address with the router.
To change the router's IP address you might needing to access the configuration page of the router, then proceed to the LAN settings.
Mar 24, 2009 | Belkin (F5D5231-4) Router
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Nov 25, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7230-4) Router (587009) Logo
121 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
