Question about Cameras
Jvc video recorder. cassette will not eject - Cameras
  • 1 more comment
  • gungadein Jul 08, 2008
    I don't know what is a "hard reset" but will explore. I am new on this site - have patience - i will will appreciate any help, clive
    I had the top off but short of bending parts out of the way I was unable to remove the cartridge. The model is JVC.HR - J220ea
    i am lost
    Genius:
  • 1,665 Answers
Have a look if link below reffers to your model manual
http://www.instruction-manuals.co.uk/category/videos/jvc.htm
Posted on Jul 08, 2008
  • Cameras Master
  • 19,396 Answers
If tape is stuck inside all you can do is removing the cover and removing the stuck cassette from inside. If the tape inside is broken or damaged you can repair the tape after extraction.
To remove the cover you should start by removing the 4 (or more ) screws on the lower part of the VCR.
In this guide you find general instructions on how to take apart a vcr to remove cassette stuck inside .
  • 4,472 Answers
Your best bet would be to send it in for service. There are quite of few places you can call for a free estimate. If you need any help locating a repair center or any other assistance let me know.
Thanks,
Lee
    Genius:
  • 1,226 Answers
The mechanism inside maybe malfunction, try to shutoff the recorder and then take out the battery or unplug to the wall outlet. to keep hard reset setting.
fix back and then switch on the jvc.
melnavz
  • Emelio Navaja
    Emelio Navaja Jul 08, 2008
    that is hard reset as i explain. however if this not resolve the issue, you should have to self tech the JVC. you have to open it and find the error inside. but its better to call the vendor if hard you to do so.
    sometimes hard reset is the cure.
    melnavz
  • Emelio Navaja
    Is there any parts that preventing the cassette to eject? you should be careful you if you have manually remove the tape.
  • 13,433 Answers
Ok, you will have to take the top of the VCR off and remove the cassette manually. assuming you don't have any warranty so there is noting to loose.
  • Ekse Jul 08, 2008
    Let me know if any problems come up,
    If you succesfully removed the casette please accept my solution but incase you need further instructions I will need to know the model of the vcr.
    -reply / comment will send me a message.
    -requesting more assistance / reposting the problem will reject my support.
    Thanks,
    Ekse
    Guru:
  • 1,894 Answers
Make a hard reset and try to eject
  • dewan nafees ahmed Jul 08, 2008
    leave the unit plugged off from the power for 2 hours and then try to pwoer On the unit and eject the tape.
    if the problem persists then you will have to remove the cover the unit to acess the tape.
2 Suggested Answers
satavlad
  • 405 Answers
SOURCE: Video camera appears to record, but nothing plays
Try to run cleaning tape, it may solve your problem.
Posted on Nov 22, 2009
Testimonial: "Worked GREAT! At the time of posting, I had not gotten the "Use Tape Cleaner" popup on the camera screen, which finally appeared last night. THANKS!"
Jvc minidv cassette not working display saying end tape does this mean tape has come loose.
End tape means that you have recorded the full 60 standard play or 90 minutes long play and you should rewind the tape or eject it.
Oct 15, 2013 | JVC GR-DVL100 Mini DV Digital Camcorder
I have a JVC, DVD recorder/video cassette recorder, model DR-MV7SU. When I try to rewind the tape, it will stop and try to eject the cassette, the tape gets commingled inside, What can I do or what website...
Hello
Check all the belts in the vcr mechanism. Replace them all at one time. You can get it is kit form, from most of the electronc spare part shops at your town. Give them the model number of your device. They will select it for you. The fault is with elongated driving belts. OK.
Jun 29, 2011 | JVC Televison & Video
Eo3 safe mode
Problem with reel, could be your cassette causes the problem.In case your cassette stuck, eject the cassette by applying power on it and keep cassette door open for 5 sec or more until cassette ejected, then use other cassette. Otherwise have it check by the expert. Good Luck
Mar 04, 2010 | JVC 580136 Camcorder
Have a jvc camcorder turn on and it says safe mode remove battery
Forget the battery, the mini dv carrage assy can get out of sync and initiate the safe mode, if you noticed a problem loading the tape or have heard a gear skip sound thats the problem. The best you can do with those camcorders is keep the tape in the camcorder!!!!! That will prevent the problem and insure many good years of recording.
Sorry,
Tim.
Jun 11, 2009 | JVC GR-D290 Mini DV Digital Camcorder
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC-GR-D371U
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
My ZR30mc video recorder will not eject cassette
Take the side panel off to see whether the tape is damaged and will not retreat into the cassette ( this will prevent ejection ). Remove old damaged cassette and insert new one. If the unit chews the new cassette camera should go in for VTR service.
Sep 01, 2007 | Canon ZR30MC Mini DV Digital Camcorder
Cameras Logo
112 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
