Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
My dryer says LOC on the little screan. If I press cancel or start it does not do anything. What can I do to start my dryer? My dryer is a Frigidaire affinity Dryer.
SOURCE: Error code LOC on frigidaire front load dryer
This worked for me. The LOC indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Posted on Feb 17, 2009
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
localwonder
  • 6784 Answers
SOURCE: estate dryer wont engage
Check the following--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Posted on Jun 01, 2009
SOURCE: My Whirlpool Duet dryer's electronic controls are
I have a four year replacement warranty and so I called customer service and a certified repairman is scheduled for tomorrow morning. Thanks.
Jubilant
Posted on Oct 01, 2009
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Error code LOC ?
LOC means that the control lock has been engaged. (This feature also keeps a child from changing any setting when a load is in progress or starting the dryer with the cat in the unit.) On at least one Frigidaire dryer, press and hold the Options and Select touch pads for at least 10 seconds (until the display changes) to toggle the lock on and off.
Usually, the two keys to press for the Control Lock will have a line between them with a padlock symbol in the middle of the line. (This symbol will be in a very small font.) This may help you find the keys to press if other models of Frigidaire dryers use a different combination of touch pads.
I hope this helps.
Oct 24, 2013 | Frigidaire Electric Dryer
My dryer says (loc) and will not start
  • Hold the "Control Lock" button, located in the bottom corner of the controls, for five seconds.
  • Release the button when the small LED beside the button lights up. Hold "Control Lock" for a further five seconds to cancel.
  • Nov 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
    Frigidaire dryer faqe7001lw blinking lights
    Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
    Apr 07, 2012 | Frigidaire FAQE7001LW Dryer
    Error loc on frigidaire dryer
    Oct 18, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
    Dryer code says "loc" and
    Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
    Jul 20, 2011 | Frigidaire Electric Dryer
    My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
    Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
    To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
    http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
    I hope this helps.
    Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
    ERR LOC on display
    Your door lock switch needs replacing.
    Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
    The LOC flahes on my display, it allows me to pick a cycle but i can not start it. Please help, i tried to press options and select at the same time for the LOC to stop flashing...is there anything else...
    "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
    Thank you !!
    Jun 19, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
    My frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please help
    Apr 15, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
    Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
    178 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
