Question about Sony Audio Players & Recorders
I just bought a Sony SRT-DN610 AV receiver and I'm having some difficulty with the video output. Here are the devices and their connections Rogers HD cable box [component and HDMI output available] Sony Receiver [ 4 HDMI IN and 1 OUT] LG LCD TV Originally I tried to connect the rogers box via HDMI to reciever, then using another HDMI cable I connected the tv IN to receiver TV OUT. My remaining problem is with the Rogers HD cable box. When I connected via HDMI, the image/sound would cycle in between the t.v. station (flash as well) and then no signal. The only way I could get it to work is by connecting the cable box directly the t.v. via HDMI, and sending the audio from the cable box to the Audio in connectors on the receiver. From my understanding, I should be able to connect by using HDMI OUT from cable and IN to receiver, and then HDMI out from receiver and IN to tv. Any idea about the connectivity issue
5 Suggested Answers
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
djnick989
  • 1067 Answers
SOURCE: sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
The Machine
  • 788 Answers
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Posted on Jul 09, 2008
smarthome2
  • 1114 Answers
SOURCE: NO audio on my TV/PS3 while TV connected with receiver via HDMI
Check the audio settings in the PS3 console. Then check the firmware version of HDMI that your receiver uses. It may be listed on the manufacturers webpage or in your manual. It must be 1.3a or 1.3b in order to work with your PS3. The downside to this is that there is no firmware "patch" to correct the problem. If you still have issues, post a reply on this thread and I can help you further and give you some options that "Will" correct the problem without degrading video and audio. Hope this helps.
Posted on Jun 16, 2010
I have a new Yamaha AV receiver rx-v381,trying to connect an old CD DVD player, Sony dvp-nc665p. I have audio, no video. No HDMI on CD DVD player. What am I doing wrong? Help!
On my Yamaha AV receiver, DVD video (usually a yellow connector) passes through to a video output which then connects to the video input of the TV.
Feb 11, 2017 | Sony Audio Players & Recorders
How to connect Sony dvd player to onkyo TX-8511 receiver
The TX-8511 is an older AV receiver with only composite video inputs. Your DVD player may not provide this type of output as it's not capable of HD video. If your dvd player has a composite output with a Red, White & Yellow set of outputs, that will connect into the Video 2 inputs on the receiver. Your TV will need to connect up to the Video2 or Monitor output. You'll need a set of composite video cables with the red-white & yellow RCA type plugs.
Here is a link to the manual for this receiver:
Receivers Receiver Stereo Receiver AVR TX 8511 Onkyo USA
Mar 13, 2015 | Onkyo TX-8511 Receiver
Connect tv audio input output receiver
Just make sure that you are using cables that are configured correctly physically and check to make sure that you are using the correct analog or digital signal necessary. Your audio settings need to be checked out and set accordingly. Check directions carefully.
Sep 03, 2017 | Sony DAV-DZ100 System
Can i hook my lap top up to this tv to get netflix? How?
Hello
This model CRT tv cannot be connected directly to lap top. Laptop has VGA output and there is no VGA input to this TV. Tv has only AV sockets to connect in. You must have a VGA to Audio Video converter to be used in between TV and Laptop. This device can be bought from electronc shops. It will have a VGA input, and audio video output. You have to connect your laptop to this device using a VGA to VGA connecter, and from this devices' output, you will get audio video output, which can be connected to TV and select the TVs' input to AV. OK.
Jun 03, 2011 | JVC AV-27F702 27" TV
What is HDMI
Its a vidio/audio input which looks like this. If you have an hdmi port on a laptop you can connect it to a TV and have the audio and video transfer to the TV.
Mar 16, 2011 | Computers & Internet
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
I HAVE A SONY RECIEVER SRT-DE597 6.1 CHANNEL AND I ITS ON PROTECTED MODE CAN YOU HELP ME UN PROTECTED
Amp output is damaged and needs repaired. Protect mode cannot be deactivated. When amp is repaired and operating normally protect mode will not be displayed.
Aug 29, 2009 | Sony STR-DE597 Receiver
Philips E-Box FTR9965 DTV Receiver and PS3 connection problem
maybe your ps3 is set to hd output and not standard av so it's trying to send the signal through the hdmi port. if so, you need to hold the power button for a certain amount of time (it tells you in the manual) and it will switch to av output.
Dec 25, 2008 | Sony Playstation 3 (PS3) Console
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
102 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
