Question about Dryers
My GE Dryer that is around 3 years old squeals or screeches loudly when drum it moving. What could be causing this and is it possible to take apart a new GE Dryer yourself?
  • 472 Answers
Its a chore but can be taken apart.... the unit most likely either has bad rollers or the belt tensioner which is under tub is bad... has a wheel on the tensioner that guides belt adn could have a bad bearing ....good luckkkkk
Posted on Dec 31, 2010
Model 69822 is less than 8 years old. Screeches loudly for about a minute on startup. Runs fine after that and dries the clothes.
The screeching is probably a slipping belt. This can be caused by"
1. Glazed or worn out belt.
2. Improper belt tension.
3. Overloaded dryer
4. Bad drum bearing
If it is used heavily (often), I would assume #1 which is the cheapest and quickest fix. You can investigate #2 at the time of replacement.
Jan 26, 2016 | Kenmore Dryers
Dryer is getting very noisy. Does this mean there is a problem ?
The most common reason for the dryer drum to stop spinning is if your drum belt has snapped or has been worn down completely. This is an easy fix and simply involves buying a replacement belt and feeding it through the pulleys and on the roller and then back around the middle of the drum.
The rollers could have worm out causing the drum to spin in a bumpy and noisy manner , these are the little circle shaped objects your dryer actually sites and can usually be replaced depending on how old your dryer is. The pulleys could also be broken causing problems.
The motor could have died after many years of use if the drum is not moving at all and if it is moving the motor bearing could be off causing to spin around very roughly and sometimes scratch against the sides of the dryer compartment.
Noises coming from the dryer when its plugged in and spinning could also be due to a huge amount of dust built up around the dryer drum. Sometimes cleaning out the inside of your dryer and returning the drum to the correct position can fix this problem.
Screeching noises are not a good sign and sometimes its a sign that you drum is slowly cutting into the sides of your dryer which could permanently put your dryer out of use if its continues.i think i will work out
Dec 16, 2010 | GE Dryers
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Loud screeching. looks like drum bearing is broken
Welcome to the world of appliance repair. A dryer is a good place to start. Check Repairclinic.com for parts and help, it's a good site. You're going to have to take the dryer all apart. The trickiest part is the belt. Note how it goes, or you're doomed. While in there, vacuum all the lint, it's a fire hazard, and gets into places it doesn't belong. Use a high temp grease on the roller shafts, and replace the belt while you're at it, they are cheap. The glides and felt need to be in top shape, they keep the dryer from eating clothes. On some models you need to pop the top. Use a putty knife to push the spring catches at the front corners. Inspect all around for bearings and things that might wear out.
Apr 24, 2009 | Dryers
Maytag atlantis dryer squeals very loudly when running
you have answered your own question! The belt will have become loose due to age/stretching. You hear cars making the same squealing noise when thgey rev up. Its a real squeal/screech. It may possibly be the drum rubbing on the chassis due to beariing failure, but doubtful.
So on some machines the motor is on adjustable brackets that let you move the motor away from the drum pully by loosening the bolts/nuts and then re-tighten. Don't leaver the motor down and then lock off the nut/bolt as this will make the belt too tight, and cause the belt to fail or the bearing to fail over time Take the back cover off the machine and all will be revealed.
best of luck it's a simple fix if your diagnosis is correct
Nov 13, 2008 | Dryers
Noisey dryer
Peace bumbabob,
Huuum t your service!
1-it may be the belt squealing or high pitched noises telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on! I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
3- I've seen also a few times that the motors heat shield, a simple piece if tin with two screws or bolts holding it down was "loose" and vibrating causing a loud metal squeal noise all the time or intermittently!!
If I were there hands on I could fix it!
Only a trained laundry tech can make the electronic diagnoses.
Unfortunately, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU
Sep 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
