Question about Video Game Consoles & Games
I have a Dynamo DH-100 air hockey game and it will not turn on. on the score board it keeps giving me Flashing 00''s s and then flashing CC 's any suggestions? thank you kevin
kman203
  • 99 Answers
SOURCE: gamer score
Try to log out of XBOX Live and then sign back in.
If not contact Microsoft and see if they can research it for you.
Call 1-800- 4MY XBOX.
Posted on Mar 24, 2008
SOURCE: harvard air hockey scoing system
The controller is poorly designed and likely burned out. I am assuming you bought your's used. If it were new, you would see that each segment of the LEDs would burn out over time and stop displaying. I am rebuilding mine - I bought a microcontroller and and writing the programing from scratch. I have identified all of the pins on the controller and it will plug into all the cables on the bottom of the table. should have it done by New Years. Let me know, if it sounds like your problem. I can build an extra one - I'll check back here to see if you are interested.
Posted on Dec 17, 2008
rylee_smith
  • 8619 Answers
SOURCE: Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 01, 2009
webethpsap
  • 9 Answers
SOURCE: x box tray keeps, opening and wont read games. power light keeps flashing
360 or regular????
Posted on May 25, 2009
  • 4 Answers
SOURCE: ps3 wrecked
it has a bug if it is a 40 or 60gb they are the ones that have it.
Posted on Jul 08, 2009
THE SCORE BOARD DON,T WORK
Please share with us what kind of a game were you watching. Football, basketball, hockey? what?
And, where were you ?
What start, county, city, or school.
Perhaps someone knows the final score of the game you watched, if you left early.
Jan 18, 2018 | The Computers & Internet
How much does an air hockey mallet cost?
Air hockey mallets generally cost around $5-$10, depending on the brand. For example, you can get one Dynamo mallet for $9. You can also find a set of two for around $12-$15 on Amazon. http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dsporting&field-keywords=air+hockey+mallet
Aug 08, 2012 | Sport & Outdoor - Others
What company makes the official air hockey tables for competitions?
Official air hockey tables for competitions are solely made by Dynamo.
What's the best air hockey table?
The Valley-Dynamo Hot Flash 2 8 Foot Air Hockey Table is considered to be the best Air Hockey table of all times, this table is the standard table of all the professional tournament although it's price is a bit price if you want to buy it, something like 4000 dollars.
Jul 25, 2012 | Sport & Outdoor - Others
What's the use of the Air Hockey Mallet?
The Air Hockey mallet is used to strike the pucks along the Air Hockey table in the direction you want to strike. You should strike the puck with enough force in order to be able to score a goal at the other end of the table, after a couple of game you'll get the idea.
Which Air Hockey table should I buy?
If you want an approved for USAA tournaments then you can check out any of the 8 foot long Dynamo Air Hockey table, just stay away from the "Hot Flash" series.
In the "Hot Flash" Air Hockey tables the painted rails make the puck fly off a lot, and fluorescent table-top makes it hard to see the puck.
A new Dynamo table price varies from $1500 to 2500$ so you should take it into consideration.
What is the best air hockey table?
It really depends on what you are looking for: who are the players - young or adults? Do you have money limitations? Do you have space limitations? If you are looking for the nest one, try the Dynamo Hot Flash II Air Hockey Table. Its $3,800. If you want cheaper tables you can go to: http://www.justairhockeytables.com/ and sort them by "best sellers" you'll get the most popular ones.
Jul 09, 2012 | Sport & Outdoor - Others
Air hockey table keeps scoring on it's own.
This table uses low voltages for the scoring lever. I agree with fixer1950. Check / disassemble the goal / scoring assembly, and look for the scoring lever. sometimes just 2 metal plates. should see where it's touching the scoring strip and you can test it by moving it with your finger / pen / other device.
Try adjusting it further away, and test again with a puck to ensure proper operation..
Jan 01, 2009 | Harvard Xh 7000 Hockey Table
Sportcraft Turbo Hockey table will not power up
The customer service is somewhat oblivious to their inventory and products they sell. But, if your table is not pushing the puck, call and order a new fan (easy swap out). Also, you may use a small pin and poke each air-hole as dust accumulates and clogs system (do not use a wax or polish, only damp soft cloth)
The control box is the interface to power scoreboard.(kids pushed the transformer cord in too hard and separated the circuitry panel inside CB). I am in process of replacing mine, model number 34090, part number 34090HG08, $5.00+ SH
There are comparable control box modules for similar turbo hockey games, Atomizer, which uses a similar control box that you can swap circuitry out to your old box. (Very simple, even a cave man can do it..hah). The key is the ability to put control box back together once you disassemble inerts. (The "flip" mechanism is so shoddy it never goes back together right)
Good luck with Sportcraft and their disposable $500-600.00 air hockey tables which have a lifespan of parts of less than 5 yrs!
Nov 17, 2008 | Fat Cat 7' Air Hockey Table
Video Game Consoles & Games Logo
112 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
