Question about Acer AOpen MX 3ZA (91.88110.101) Motherboard
Computer will not boot with Pioner Blu-Ray BDC-SO2 installed.
New computer with ASUS M2N8-VMX motherboard, 2 Gigs RAM, AMD Dual Core CPU, one WD 160GB SATA Hardrive and One PATA DVD Drive with Win XP Home.
Boots normally until I install Pioneer BDC-SO2 SATA Blu-Ray drive.
Have flashed drive with Pioneer Update, still no go.
Computer appears not to be able to see Hard Drive to boot.
Sticks on Windows Loading with loading indicator running continuously
Boots OK in SAFE MODE and can see all drives.
Have reloaded Windows and Asus M/B drivers and utilities several times.
It would appear the two SATA drives are fighting over which one is Master.
Any assistance or thoughts would be gratefully appreciated.
S. Tokarek
    President:
  • 2,351 Answers
Hi stokarek,
With respect to SATA drives. All are master drives. As you mentioned if there is a fight between drives the trouble can be settled in the bios. I gather the WD160GB drive holds windows on it & the WD is connected to SATA 1 port. Enter you're bios & go to the Boot section. Open you're manual to section 2.6 boot menu page 2-32. Make sure you're WD is the only hard disk drive listed. After you add the Blu-Ray (To SATA 2 port), (its pin setting should be set as master. Than go back to the boot menu & make sure the Blu-Ray drive is listed under the WD drive.
Keep in mind for the future that if you want to boot to the Blu-Ray drive you'll need to press the F8 key at boot up. Windows select boot device window will open & high-light the Blu-Ray & press enter so the Blu-Ray will boot. Windows should no longer stall. If this does not work try switching the pin on the blu-ray to slave. (I'm not sure there is even a pin setting on the blu-ray drive. Never the less the bios boot order is the boss.
Link to Asus main driver site for ASUS M2N8-VMX
http://support.asus.com/download/download.aspx?modelname=M2N8-VMX&SLanguage=en-us
Good Luck stokarek!
Mike
Posted on Jul 08, 2008
  • 101 Answers
First check you os compartabitly then instal and first you shouls instal the anti virus
Posted on Jul 22, 2008
In call of duty ghost do i need to buy 1 whole 8 gig of memory
You need to have 6 gigs of free dynamic ram.(Not including that used by the operating system and any other applications you have.
The way that memory is organised in a computer these days is usually in pairs or DRAM (dynamic random access memory) sticks which are matched. This allows the CPU to withdraw data from both memory sticks in the same clock cycle (DDR double data rate) which improves the over all speed of the processing.
So legal combinations over 4 gigs which will use the dual channel feature on your motherboard will probably be.
2 x 4 gigs sticks = 8 Gig DRAM
2 x 8 gig sticks = 16 Gig DRAM
Below is the minimum specification requirement.
Note: MINIMUM Faster CPU better graphics card and More ram is better.
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better CPU Speed: Info RAM: 6 GB OS: Windows 7 64-Bit / Windows 8 64-Bit Video Card: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better Sound Card: Yes Free Disk Space: 40 GB
Feb 24, 2015 | Activision Call of Duty: Ghosts Full...
I loss my asus m2n8 vmx driver. my procesor is AMD i reformat my computer. but i think i need at audio driver help me please!!
if you found audio driver of any motherboard go to my computer , manage, device manager go to property on device whose driver are not found copy device id code use this site http://devid.info download suitable and small size use update driver for install driver enjoy these steps
May 29, 2011 | ASUS M2N-MX Motherboard
To upgrade to a newer and better CPU processors enabling me to play more quality games Min requirement CPU type and speed Intel 2 duo or equivalent What types and models and specs please. Have at...
You should get a quad core processor, with a minimum of 3 to 4 gigs of ram, and an asus SLI or crossfire Motherboard. This and a nice 1 terrabite drive can be done for under $500.00, unfoutunatelly, thats just the way they make it. I PLAY cod4, and I run a dual core with 2 gigs of ram and a $300.00 asus MB, with twin 7900 video cards in sli. and it just about runs it, the new games are processor and ram intense, let alone video cards. I would suggest a single card if cost is a factor, you can always add a second or even a third card later. But the you don't want to be the slowest guy playing, especially if you like first person multiplayer shooters
Jun 12, 2010 | Compaq Computers & Internet
Upgrading from amd 3500+ cpu to 3800 duo
2 short beeps is memory parity error. Does the motheboard support dual core? Did you buy the correct socket type processor to match the mb?
Feb 19, 2010 | ASUS Computers & Internet
I have bios version 1008 on the computer. Should i update the bios version to the newest one? The fans are always running, they never shut down
Actually if your MOBO are working fine as of now no need to update the BIOS version. Updating BIOS version may affect some parts of MOBO so no need to update the BIOS version.
Regards
nicole
Oct 03, 2009 | AMD Asus A8V Deluxe Socket 939 Motherboard...
I can't install windows vista and windows 7 when i want to install vista or 7,(boot from cd-rom or install from win xp),it's hang up! My Mainboard is ABIT AX-78 VGA= ATI Radeon HD 4800 Series 512 DDR3 RAM=...
There are lots of compatibility issues with vista and hardware. Please run the vista compatibility program from microsoft.com prior to trying to install. It will tell any and all potential issues
Aug 30, 2009 | Computers & Internet
I need the drivers for M2N8-VMX
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2N8-VMX
The motherboard it self does not have a driver, but it's components do, just so you know/understand :)
Feb 27, 2009 | ASUS M2N-MX Motherboard
I cant find from the web driver of m2n8-vmx motherbord...nid help
Hi there.
Get all the motherboard drivers from here:
Good luck and thanks for using Fixya!!
Feb 13, 2009 | ASUS Eee 4G Notebook
Acer AOpen MX 3ZA (91.88110.101) Motherboard Logo
334 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
