Question about RIM BlackBerry 7100G Smartphone
On start up
Abort exception reset
then i get on reset
tcu exception reset
then i get on reset
device errors 400
then i get on reset
    Brigadier General:
  • 7,752 Answers
You have a firmware problem try updating the phone's firmware or take it to a mobile store and have the firmware reflash.
Posted on Sep 14, 2008
Error 10054 on windows 7 home priemim
Winsock error 10054 is "Connection reset by peer", or "An existing connection was forcibly closed by the remote host". The error means exactly what it says - the remote host closed the connection unexpectedly. This happens when a connection is aborted, and there is no tcp disconnection handshake (fin, fin ack, ack) , but instead a rst (reset) flag is sent. A reset flag aborts the connection, and can be sent when:
- The device is suddenly stopped, rebooted, or loses its network connection.
- The device uses a "hard close". With IP*Works! a hard close never occurs unless you specifically set the Linger property (IPPort, IPDaemon) to false.
- A "half-open connection" state occurs. That is, when one device not been receiving acknowledgements of the data it has sent, or it receives acknowledgement for an unrecognized sequence or ack number, it will send a rst flag to reset the connection. This particular case could have a variety of its own causes, such as misconfigured proxy/firewall or network quality issues resulting in too many dropped packets.
May 30, 2011 | Cameras
Handset shows abort exception reset how to reset this.
"Perform a hard reset on the handheld by pressing the Alt key + the Cap key + the Del key, 2 times"
To specifically answer your question, a hard reset is simple a removal of the battery and reinserting it.
However, you wish to do more than that, you want to wipe the device.
You will need to use JL_Cmder to wipe the device and subsequently load the OS to the device. Follow the instructions here:
http://www.blackberryfaq.com/index.php/How_do_I_wipe_the_BlackBerry_using_Jl_Cmder%3F
Dec 10, 2010 | RIM BlackBerry 6230 Handheld
Transmission stuck in forth gear check engine light is on.
Your TCU (transmission Control Unit) is bad. it is located behind the passenger side kick panel. you can purchase it on ebay for about 79.00 with exchange.
Lugnut61
Feb 08, 2009 | 1992 Honda Accord
Blackberry 7100v - abort exception reset
I have a 7100x Blackberry and when I recently connected to my laptop for charging, my screen vanished and a white screen appears saying- Abort exception: Reset. How do I solve this?
If I reset the system shuts off...
Pls Help
Aug 15, 2008 | RIM BlackBerry 7100v Handheld
Clearing all content ..how does one accomplish that task?
How does someone clear all the content of a blackberry? I got an error message saying abort exception reset, what can I do to get passed that or fix it?
Jul 31, 2008 | RIM BlackBerry 7210
Blackberry 7290
for that problem you should re-install the blackberry system for your pda and it would work! good luck!
May 13, 2008 | RIM BlackBerry 7290
Phone keeps turning on and off (had gotten multiple errors)
my blackberry 7100t was dropped and now the problem is its screen keeps on fading off and colours keep on changing again and again..the screen comes nack to normal if the screen backlight is switched off for around 5 min..it will work normally for sometime may be for ten fifteen min and the problem starts again..suggest some solution for this..and also if u could advice me from where i could get a new battery for the same phone..
contact:
madhur@priest.com
May 12, 2008 | RIM BlackBerry 7100t
Blackberry 7290
You will have to reload the Unit software. If you can let me know what your carrier is, i can provide you with the links and instructions for obtaining the software and installing it.
Once the software has been re-installed, it should boot up fine.
Let me know if you need any additional assistance.
Zexxal
Nov 14, 2007 | RIM BlackBerry 7290
Dropped Blackberry 7100
if you take battery out and back in and the problem is not resolved, you may wish to take up skeet shooting.
sorry
Oct 20, 2007 | RIM BlackBerry 7100v Handheld
RIM BlackBerry 7100G Smartphone Logo
279 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
