Question about Dell Latitude D610 Notebook
Problem with the ON/OFF button
Hello, I have a problem switching on my PC. It seems that the ON button doesn't work anymore when I push it, and I was wondering if there is a way to switch it on in a different way or to solve the problem using a sort of autorepair functionality.
Thank You
There is common problem with a cold solder joint on one of the components with this board. When the button is depressed, it breaks the contact, if you can reflow the solder joint it will work fine. Otherwise you can buy a new board on ebay adr replace it. To reflow the solder joint you can either heat it with a heat ggun, or a small soldering iron.
Posted on Nov 02, 2012
    Genius:
  • 2,028 Answers
The power button is the only way to turn it on. Remove the plastic strip that contains the power button, do this by lifting up at one end, it will then pull up and off. Then you'll see the power button on the board, try pressing this button. If it starts normally, then the button on the plastic strip isn't making a good contact with the button on the board, replace the strip. If it still doesn't turn on, then power button on the board is faulty and will need to be replaced. You can find the plastic strip on Ebay for a decent price. The power switch on the board is harder to find. Most sellers on Ebay leave this attached to the motherboard when they sell a parts machine, you're best bet is a shop that deals with used or refurbished laptops.
Posted on Jul 08, 2008
Advice for when my coputer screen freezes and the esc button doesn't help
Hi Donna,
if everyting is frozen and you cannot do anything with your computer, you can wait a couple minutes to see if it is only working on something in the background that is taking up all its resources... if it does not start responding by itself, and you do not want to wait anymore... push the PC's start button that you use to turn your computer on (not the windows start button) for 8 seconds and it should turn off. NOTE: any changes to data that was open and and not saved will be lost.
Hope that helps
Jan 02, 2013 | Dell Computers & Internet
My honda accord 20005 2dr. driverside seat belt sensor doesn't register anymore when connected
check to see if the wire has came loose leading to the seat belt disconnect button you push when releasing the seat belt if connected. then will have to replace that part of your seat belt the sensor or switch in buckle may have broke
Oct 20, 2012 | 2005 Honda Accord
Folding button detach
Hi Frank - Glad to hear that you've managed to rectify that issue!
Nov 27, 2011 | Quinny Baby Gear
Hello Gents, BM 450 situation: filled all ingredients inside, selected programme, pushed start/stop button - working. Butafter 15 min i realised that i choosed the wrong programme and i wanted to stop the...
By unplugging your machine you probably engaged the power failure safety device. You need to clear your programs by pushing the "stop" button until it beeps or the readout changes, (this usually only takes about 5-8 seconds. Then push program, choose the program you originally wanted and push "start". Please let m know if this works for you.
Nov 26, 2010 | Kitchen Appliances - Others
Hello, I have the Asko W6761 and all of a sudden it doesn't run the cycle anymore. It starts normally, i.e. pumps water into it, but then it doesn't start to wash..any idea what this could be? After a few...
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Toggle the power switch
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
W6761 seems to be weak at high ambient temperature.
Tsunett
Oct 26, 2010 | Asko W6761 Front Load Washer
Gate (operated by push button) open by itself
could be picking up a signal that is telling it to open from somewhere else. seems the button just supplies power to it from the way you explained it
Jun 13, 2017 | Gardner Bender #GSW-22 Push Button Switch
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
BenQ computer start button doesn't work sometimes
Recommend replacing the switch with a new one. Usually the button is just a cover and mounted on the Chassis face. The real switch is behind the plastic button. You'd probably have to remove the front panel or go inside the Chassis to get at the switch. The switch will have a couple of wires that connect to the mother board "Start" pins. The wires can be unplugged from there.
Jun 10, 2009 | Computers & Internet
Remote start on car
it seem our remote is deactivate you mush have a bypass switch or valet switch maybe it off because if the module would be blown nothing would work lock under the dash i understand about cold im in montreal cheers p.s get ride of that boyfriend who mess with our car take care
Jan 21, 2008 | Car Audio & Video
Dell Latitude D610 Notebook Logo
339 people viewed this question
Alun Cox
