The machine does not hold the water . It starts to drain while it is still filling
  • 472 Answers
Not sure what brand dealing with here.... is there any water on floor.... if not then your drain hose is to low... if it ran fine before like this then possible you got a bad pressure switch on unit located in control panel....
Posted on Dec 31, 2010
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Washer will not hold water
You need to check drain hose, the drain hose needs to be above the tub. If it isn't the water will just drain out when you fill
Jan 12, 2010 | Washing Machines
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Continues to fill, not holding water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
If the above adjustment doesn't produce positive results, replace the control.
May 31, 2009 | Crosley Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Can't hold water
There is no drain valve.
Pull the drain hose up out of the drain pipe until there is only about 6" inside the pipe. Make sure there is a gap around the hose where it goes into the pipe so air can get in.
Make sure the drain pipe is higher than the water level in the tub.
Nov 17, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
