Question about Nintendo Video Game Consoles & Games
When I turn on my Wii the startup screen is totally black, the sound is working, the remotes sync and the green light is on, what could the problem be? I've tried different cables, I've tried it on another TV, I've tried everything I know to try so far and nothing seems to get my menu back on the screen it's totally black. It acts like it needs a system reboot or something.
  • Anonymous Dec 31, 2010
    I already tried new av jacks.
  • 25 Answers
You will probably need to buy new av jacks for it
Posted on Dec 31, 2010
  • David Zakrzewski Dec 31, 2010
    see if any of these work
    http://www.wiipals.net/Forum/f34/wii-bla...
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
I turn on the wii and the green LED comes but Black Screen
Assuming you did not tamper with the system (mod it to play burnt games) then that is usually caused by the BlueTooth module not working.
If it's under warranty then send it back to Nintendo. They are very quick and very good.
If it's not, you could try replacing the Bluetooth module yourself. I get mine from http://parts.consolerepairguy.com for about $22. I fix consoles so I know that is usually the cause.
Oct 23, 2009 | Nintendo Wii Console
Wii has black screen and no sound when I turn it on
Make sure you have the input set correctly on the TV. If you turned everything off, it probably reset back to default input.
Jan 02, 2009 | Nintendo Wii Console
Green light stays on, black screen, no sound, no connection w/ remotes
Go to the tv settings and check to see if you blocked any incoming devises. If you did block the devides, your tv will not read the wii
Jun 11, 2008 | Nintendo Wii Console
Power is on but screen is black
I found this [temporary] solution at http://www.wiierror.com/wii-black-screen.php:
(via email, thanks Steven) This happened to me once, but I fixed it. Here is how:
Eject the disk
Unplug the wii at the back
Wait 1 minute
Plug it back in
Turn it on from the remote
Press reset if it does not show up
Hold the power button to shut it off
Turn it on once more.
I don't know how, but it seemed to work for me. The problem happened when I was trying to load the Mii channel. Hope this helps !
(via email, thanks Andrew)
The first time I shut down my Wii, the light went orange (as it should). When I turned on the power with my wii remote the next day, the wii\'s light turned green but the screen was black.
The treatment was the same as from Black Screen, No Connection: Unplug the Wii\'s power supply unit, then replug; turn system on with wii remote.
The difference is: this problem can strike in more places than just by loading the Mii Channel. Also, I think the green light being on (yet there being a black screen) is a common symptom as well.
May 18, 2008 | Nintendo Wii Console
LED turns green, but console doesn't start up
hum........ that is weird I'm not really sure how to fix that. But make sure all the cable from the wii are plugged in properly. For example: the red, yellow and white cables may look like they are plugged in but sometimes you have to push them in really hard to get them to work.
My wii does that sometimes in the middle of a game it just goes black so I just have to walk up to the TV and make sure they are im properly.
May 17, 2008 | Nintendo Wii Console
Wii LED Green, but no Startup on screen. Cannot power off either.
Just spoke to Nintendo Technical support.  Seems the rub is in the AC adapter itself.
Need to power down at both ends of the AC adapter--unplug AC adapter from wall output AS WELL AS from back of Wii.
Wait at least two minutes to allow any charge in the adapter itself to dissapate.  Plug adapter into wall first, then back into the Wii, making sure your peripherals (eg AV receiver, TV, projector if using) are already on.
Tech support says sometimes you get a partially tripped "fuse" within the AC adapter itself.
This seems to have worked for now--will let the forum know if further problems
May 15, 2008 | Nintendo Wii Console
Green Light on, but nothing working.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#shut_off
Dec 11, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
65 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
