Question about Sharp LC46LE810UN 46 in. LCD TV
I have a digital signal antenna, but the option for it in the setup menu is greyed out & I can't select it. After double-checking the connections were right (nor loose) and running the channel search twice, I still get no signal. Help!
    President:
  • Sharp Master
  • 1,779 Answers
Auto set up
Posted on Dec 31, 2010
Functions greyed out
Greyed Out Menu Options
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - Home > Setup & Installation > Greyed Out Menu Options Share on Google+ ... The menu options you have access to on many Samsung TVs ...
Antenna menu is grayed out - Forums - CNET
www.cnet.com > Forums > Samsung
CNETApr 21, 2013 - I have an HD over the air antenna going into my Samsung TV. However, the antenna as well as the Plug in Play menu is grayed out and can't be selected. Any ide... ... I think I might do 1 of the these two options. 1. Buy a new ... Samsung Support for Smart TV is terrible
Jun 11, 2015
TV Picture settings greyed out?
Sep 22, 2013
Samsung Smart TV update problems
Aug 29, 2013
Grayed-out menu settings with LN32A550
May 31, 2009
More results from www.cnet.com
Why is some options in TV menu grayd out? - SamyGO
Dec 25, 2015 | Televison & Video
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
I can't get my Olevia tv (537-B11) to scan for channels
I don't know this model of TV, however, you may find that you need to use the Source button on the remote to cycle through the available inputs & select digital tuner as the input source before you press the Menu button & go into the setup section.
Jan 05, 2014 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
How do I reset my Sony Trintron KD-28DX4OU Digital TV to factory setting which I am told could resolve the problem I have whereby I cannot re-tune on digital as this option is greyed out and I cannot...
The only Factory Reset Options are in the Picture & Sound Adjustment Menus.
Have you got a Digital Antenna Connected to RF In Digital and followed the process below?
1) Press i+ button to display the Digital Info Display.
2) Press BLUE button to display the Main Menu
3) Press UP & DOWN buttons to Auto Tuning then press OK
4) Press RED button to start
Jun 14, 2011 | Televison & Video
I can not get a digital signal. i am using cable as an antenna to the draw the digital signal, it is not working. it works just fine on my sharp flatscreen.
Hello! You need to read manual carefully and check your configuration settings. it may require to select digital/analouge/antenna/cable options from configuration or channel tunning section of your tv menue
Mar 02, 2011 | Mintek DTV-265-D 26 in. LCD TV
I am having trouble recieving over the air digital signals. I have connected a 20 db amplified FM/UHF/VHF antenna to the cable/antenna coax connection, set the input to "TV", and set the TV to...
I believe you have probably selected the wrong TV mode. It seems that you have set the TV to analog mode. It is common for the digital tuning option to be greyed out in analog mode and only becomes available in digital mode. Look for a button on your Sharp remote labelled "DTV" or "DIGITAL" and press this, then open the menu and try the digital setup again. If you don't have one of these buttons, look for a button labelled "INPUT" or "SOURCE" and look for an input or mode called digital or DTV.
I will check on the exact method for your TV and post back with the details shortly.
Regards,
BElectric.
Feb 10, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tuning option on menu is greyed out. cannot retune channels
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit the icon is not greyed out and tuning is possible.
Sep 30, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Unable to tune in the digital programs after digital switchover . there is no analogue signal. when i click on menu it allows me to select all but 2 of the options and tuning is one of the options that it...
If you were unable to tune in digital before the switchover then most likely your digital reception is poor. Unlike analog signals you will not see anything on screen until it can lock in. You may have to repoint your TV antenna or check what size of antenna you need at antennaweb.org
Sep 10, 2009 | Televison & Video
Digital Television Transition and Public Safety Act of 2005
I take it you are trying to get a HD digital signal from an antenna. If that is the case, you will have to go to the menu and have it scan for antenna signals. It should automatically pick up digital channels as you scan. There may be a box to select to prefer a digital signal as well which you should have marked. It takes some time and the channels may not appear instantly. If you dont get the channels, you may need a more powerful antenna.
Dec 24, 2007 | Televison & Video
Sharp LC46LE810UN 46 in. LCD TV Logo
259 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
