Question about Amana Refrigerators
Bottom freezer refrigeratior stopped working. the amana is only 4 yrs old. I first noticed the ice cubes were starting to melt. What should I do ???? Please help.
  • mariogelli Jul 08, 2008
    I paid $9.00 to hear call a repair man....Thanks for nothing!
    Brigadier General:
  • 3,614 Answers
You may need someone to service your ref. the unit must be check for any problem or damaged...
Posted on Jul 08, 2008
  • 13,433 Answers
Is the compressor running?
  • 4,472 Answers
Most likely you will want to have someone come out so it can be serviced. That is your smartest option. Let me know if you still need any assistance.
Thanks,
Lee
  • Lee A.
    Lee A. Jul 10, 2008
    Well your other option is to grab a multi-meter and start testing is that the option you are looking for? Most times if you have to ask what to do it is out the range of expertise to service the unit. So it is more time and cost effective for a service technician to fix your problem. If you still need assistance I would be more then happy to assist. If you would like to have it serviced I can assist you with any information you need. Also we would need the exact model number to be able to fully assist you.
    Thanks,
    Lee
The ice maker on my Amana stopped working suddenly. The arm is in the down position. Why isn't it producing ice?
Check the plug in the back of the freezer to be sure it hasn't become dislodged by something. Let me know how this is, I may have another answer if that doesn't work, aside from replacing what only all the sudden stopped working. You will usually have some notice, i.e. smaller cubes, etc if it's about to fail
Sep 01, 2011 | Amana ARB9059CS Bottom Freezer...
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
MY amana refrigeratior is making a loud clicking
fan blade hitting ice or something like that. check blades to make sure not ice on them. nedd check blade clearance.
Mar 04, 2010 | Amana ARB9058CS Bottom Freezer...
Amana ABC2037DEB after 4 years, now freezer click and hum melting
that click followed by a hum can only be one thing
pull the unit out and feel the compressor, if its really hot you have a relay and overload issue, and it struggles to start.
with any luck, it is the external relay and overload found mounted to the comresssor should be a lil white block
if not it will be two differant parts
a lil white one and a brown one
let these cool a bit and check both for continutity
ive included a link for the parts
they are 10 and 11 on the schematic
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174380&diagram_id=1358665#d1358665
Oct 22, 2009 | Amana ABC2037DEW / ABC2037DEB / ABC2037DEQ...
Ice cubes melted, but items at the bottom are still cold.
I believe you solved your own prob.. definitly sounds like the fan motor stopped.
May 16, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice Maker Stopped Making Ice & Cubes are Melting (rest of freezer is cold)
can you pull the cover off the ice maker to see if the gears are bad?let me know more-mike
Oct 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
Sep 26, 2008 | Amana ABB1927DE Bottom Freezer...
Quit working
then there may be some voltage problem
Jun 23, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
