I just received the above laptop for Christmas and was attempting to make a set of recovery disks. The first disk recorded fine. I am using Memorex DVD DL disks. The second disk recorded almost halfway and then kicked out with the above error code. I have tried several different disks in the hopes that the one I chose was damaged, but to no avail. Getting a bit frustrated as I am still not able to actually use the computer and I have had it since Christmas. Your prompt attention to this matter would be greatly appreciated.
  • Jeffrey Groves
    Jeffrey Groves Dec 31, 2010
    Apparently the error code didn't make it into your question. Can you provide it in a comment?
  • 90 Answers
What is the error message.
simple if the error presits go to service center.recovery discs means os and its cost is included in laptop mrp.to correct this error is service center paople headace.software needs to be reloaded
Posted on Dec 31, 2010
    Scholar:
  • 149 Answers
Cheap DVD DL media (such as memorex) is incompatible with some burners; having experienced this myself I'd advise you to buy a spindle of Verbatim discs. A firmware update on your drive might improve compatibility with cheaper media, but I wouldn't count on it.
I don't think memorex manufactures its own discs -- they just resell other brands. It's very possible that you've picked up a dud pack. There's a few apps that will tell you the real manufacturer of your discs, and from there you can search for other users' experiences.
Having trouble with my PIONEER DVR-RT500 recording DVD+RW
(-) R is the industry standard, (+) R is Sony standard, suggest you stick with (-)
Nov 28, 2017 | Pioneer Televison & Video
My computer keeps saying disc read error i have tried everything but nothing works
When you receive a disk error, stop using the disk immediately, and do not attempt to open damaged files. The more you attempt to use a damaged disk or file, the less likely a successful recovery will be.
You can try to recover the damaged file(s) with utility programs (such as ScanDisk or Norton Utilities for Windows, or First Aid for Mac OS X), which search the disk and attempt to recover damaged areas. Recovering damaged files or disks can be risky, however, and it is possible to make the problem worse by using these utilities. Unless you thoroughly understand the recovery software process, UITS recommends that you seek professional assistance.
The likelihood of successful recovery depends on the type of damage to the disk. Information stored on disk is vulnerable to dust, dirt, magnetic fields, static electricity, age, wear, and physical disk damage. Taking proper care of disks and making frequent backups will help protect your data.
Oct 06, 2010 | Computers & Internet
Turn on laptop and it says "A disk read error occured press ctrl alt delete to restart
Oct 06, 2010 | Toshiba Satelite 2405-S201 Notebook
Trouble with DVD+RW Disks being compatiable or staying formatted
cos they are cheap - get some decent branded discs such as TDK or tayo yuden and it should be fine
Also check the manual and or requirements on there website and it should show which are the best discs to use for that player but TDK or tayo yuden should be fine.
www.svp.co.uk or any where you can buy discs from should be fine
Apr 15, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Xp pro set up
copy ntldr file from i386 folder and paste in C:\
steps
  1. Use the Windows Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\ If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.ini A list similar to the following list appears:
Feb 22, 2009 | Microsoft Windows 98 for PC
16 DVD drive will not record on 16X disks. Will record 8X disks
YOU NEED TO BURN THE DISK AT A LOWER SETTING.CHANGE BURN RATE IN YOUR BURN PROGRAM.RICHARDM69
Dec 31, 2008 | E-Machines emachines (emachinees) CD-ROM...
Just bought, set up to record with TV and used a Memorex DVD+R
you can then only use the dvd-r cd's and not the dvd-rw disc
Nov 26, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Nakamichi cd45z
The CD45z does not play MP3's ....Nak is about SQ ...since MP3's are poor quality ...this doesn't fit with what Nak is about.
Mar 03, 2008 | Nakamichi CD-45Z CD Player
Blue Screen and Computer freeze after using Memorex CD-R & DVD RW
Is it possible to try this drive in another PC? My recommendatoin, if the drive performs to specs in the other PC, would be to perform a System Restore (not the XP one, but rather the one that uses the HP disks). If you do decide to do the restore, be sure to backup anything that is irreplacable as the restore will put your system back to factory settings. Good luck!
Oct 06, 2007 | Computers & Internet
Mini DVD Camcorder Problem
You will never be able to recover the information. Sony's system really will have problems with third party brands; there is particular engineering that makes this so. In my shop (Sony authorized), I have seen this problem many times. If you insist on using other brands, get used to problems. As your laser assembly wears it will become more problematic. Good luck, magic seadog
Jun 14, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
