What do the symbols on the display mean and which one does the cooling operate better on . model number kyd-32a thanks
  • 2,133 Answers
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Posted on Dec 31, 2010
Need manual for Debo fireplace model #ZH5-32A
Try Googling (debo)(ZH5-32A)(manual) without parens.
Nov 24, 2017 | Heating & Cooling
I have my frigidaire washer mashine an it wont turn on only the word lock apears in the little window
Thank you for your inquiry, alba pinales!
From what you have described your Frigidaire washer is not operating and it is displaying the word "lock". Typically, the "lock' stands for the control lock feature. If you look at your control panel you should see a padlock symbol depending on your model you should be able to hold down the button that is near that symbol for three to five seconds. That should release the lock if you need any further assistance please reconnect and provide me with your model number. You can locate your serial tag (which lists your model number) on the door frame of your washer. With that information I can better assist you. -Matt
Feb 18, 2015 | Frigidaire Washing Machines
Kyd-25 compressor does not turn on.
with a meter you could test the amp draw on the compressor but it sounds as if you are drawing l.r.a.. This is locked rotor amps, a rating you could likely find on the data plate of the machine but ultimately means the compressor is bad.
Feb 19, 2018 | Heating & Cooling
Climachill operating manual
KY(D) & other model manuals are available on the Climachill site: http://www.climachill.co.uk/portable-air-conditioners/manuals-download/
Mar 02, 2012 | Heating & Cooling
Operations Manual For Mobile A/C Modle:KYD-25/b
Dear FixYa,
I have an air conditioning Home Pride, Model KYD-25/b and have a problem in Cool mode.
It never got below 90 F, even I set to 65F. The compressor ran for a short time then stop, while the fan kept running. It cycled like that every 5 minutes or so.
Do I have a low refrigerant and need to charge? How do I do it?
Thank you.
Hao lam
hlam1@comcast.net
May 27, 2011 | Home Pride Heating & Cooling
I have a front loading washing machine with many symbols and no mnaul. Is there a key you can give me to tell me what the symbols mean? Thanks
Go to back of washing machine and look for label with model number and serial number.
Take a photo so the numbers are easy to read.
Then search for example: Maytag RG3455 .pdf
Be sure to include .pdf in search parameter.
Another approach is to contact repairclinic.com and see if they have schematic or manual.
Also re-post question at fixya clearly stating your brand and model number to see if someone has a link or has a manual.
Better results at fixya might be available when offering $3-5, since somebody has done work to find and post manuals for your benefit.
Mar 24, 2011 | Whirlpool Washing Machine Knob - 3362624
We have a White-Rodgers 90 series thermostat that started beeping last night. We have had it for about 4 years. Does it have a battery? I couldn't find anything about that in the manual.
Susan, the "90" series of thermostats covers a couple of different thermostats made by White-Rodgers. Here's how to find your model number. With that info, I can check the manual specific to your thermostat.
In the mean time, check the display for the word BATTERY or BAT. (Flashing) on the display. Battery flashing or blinking on the digital display indicates low batteries. If the batteries have recently been changed and the thermostat continues to indicate low batteries, use a pencil eraser to polish each of the battery contacts inside the back of the thermostat. Do not bend them up and down when polishing or you might break them. When complete, they should all be as shiny as a mirror. This will assure proper battery back-up, allow the backlight to work correctly and remove the flashing battery symbol from the screen. Battery (Solid) on Display The battery symbol (not blinking) indicates a loss of power (24 volts) from the heating and cooling equipment to the thermostat. Normally the heating and cooling do not operate when the battery indicator is on. If the battery indicator is on, check the fuses or breakers, make sure the furnace is switched on, and verify the blower compartment door is closed properly. The battery display is designed to indicate the thermostat is running on batteries, so replacing batteries has no effect on the indicator. See No Heat/No Cool for more information. Note: Some heat only systems (zoned systems) disconnect power from the thermostat during a normal heating cycle and display the battery symbol. Millivolt heating systems always indicate battery because they do not supply 24 volts to the thermostat.
A beep often is provided as audible feedback when keys are depressed on many thermostats. You should check to make sure that no key is stuck in the "in" position or is otherwise activated.
Jan 10, 2011 | White Rodgers Water Heaters
I need a manual for a Clausen kyd-32/a portable air conditioner
http://www.search-document.com/pdf/1/clausen-air-conditioner-kyd-32a.html
Nov 11, 2009 | Heating & Cooling
Sharp cash register dont know what the keys are
You should be able to go to Sharp support and search your model number for a copy of the operator's manual. If it's an older model send me the model number and I'll look for one. Good luck and God bless.
Jun 14, 2008 | Office Equipment & Supplies
Heating & Cooling Logo
2,055 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
