Question about MXL 990 Professional Microphone
Is the 990 an externally polarized capsule or electret?
    Problem Solver:
  • 5 Answers
The MXL 990 is an externally polarized condenser microphone. You will nee to provide 48v Phantom power to use it. Alternatively there is a USB version, the MXL 990 USB which gets it['s power from the USB port.
Posted on Jan 01, 2011
Backup macbook pro harddrive
you can use the OSX built in "Time Machine" and connect an external HD or even better a Time Capsule WiFi station from Apple.
Can use Apple Time Machine to restore to new MacBook Ask Dave Taylor backup-macbook-pro-harddrive-abadwnk1mj4brvvpzp1wcyyy-4-0.jpg AirPort Time Capsule 2TB
Oct 17, 2013 | Apple MacBook Pro Notebook
Can not remove capsule and lever stuck
I had a similar problem, and it was down to high pressure remaining in the machine preventing the lever from releasing. You can test this by pressing the capsule in the machine (which will be much more solid than normal).
To fix, all you need to do is make a hole in the stuck capsule. I did this by drilling a small hole in the side of the capsule.
That releases the pressure (and a little spurt of coffee!), and the lever will release.
Mar 10, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Hi, I'm trying to fit the polar pattern converter to my C1000S mic. I've removed the wire mesh part to reveal the shock mount and capsule but there seems to be a black plastic bit of a different shape...
Alan, the C1000s comes with 2 filters, and it sounds like one of them is already on the capsule. Yes you can remove the one already on. I find by gently twisting and pulling it comes off easily. The capsule is rubber mounted so it can take a little bit of pressure.
Feb 27, 2011 | AKG C1000S Professional Microphone
Need to know dc voltage for simpletech external hard drive 1tb
12 volts Dc and 1.5 ampere with External terminal as Negative Polarity and internal as Positive Polarity.
Good luck
Thanks for using FixYa.
Jul 06, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
What does the polarity + - switch do on Roland PD7 & KD7 pads do? also is it possible to purchase replacement internal triggers for these & how do the thin plastic actual trigger parts work...
The polarity switch selects whether the pressure causes a positive or negative electrical spike. This can affect whether your drum MODULE fires on the hit or when the hit is lifted.
Thin plastic triggers are an electret plastic and have piezoelectric properties.when their shape is changed by pressure, etc.
Jun 03, 2010 | Roland Pd 8 Dual Trigger Pad
Stocl mike and behavior linked to temperature
Take the back off,turn it over with green side up and inspect the solder joints very closely with magnifying glass, re-solder joints,...sounds like a cold solder joint, when it heats up it expands and makes no contact...hope this helps...
May 24, 2010 | Magnum 257 CB Radio
How to use Sony Electret Condenser Mic ECM-102
The closest manual I find is at http:// www.mutinymedia.co.uk/tie_clip_mic_files/ecm44b.pdf. Shows where the battery compartment is and gives specs and usage tips.
May 17, 2009 | Sony Audio Players & Recorders
Mic not working with sound pod for T2900
yans, i have a trouble with the harman kardon audio driver for toshiba satellite m-305-s4820, would you like to send me the driver.
Apr 24, 2009 | Creative Labs Inspire T2900 Computer...
MXL 990 has really low output
These are really cheap mics! I have two dozen of them because what I do requires the mic to be expendable. The capsule is pretty fragile and just a little drop or hit to the mic can drastically alter the frequency response and output level. If you record with it and it has a hollow sound I would bet this is what happened. If you can generate white or pink noise out of your system, then record it. Just hold the mic in front of the speaker. Play it back and compare the tone of the recording to what you just heard. Hollow? There you are!
Aug 28, 2008 | MXL 990 Professional Microphone
Center Pin External Power Polarity
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Jan 21, 2008 | FireLite (USBFLB80) Hard Drive
MXL 990 Professional Microphone Logo
285 people viewed this question
Top MXL Audio Players & Recorders Experts
Ben Armstrong
drivealot
Will Godwine
Are you a MXL Audio Player and Recorder Expert? Answer questions, earn points and help others
