Question about Vizio L32 32 in. LCD HDTV
My Vizio HDTV has green/red snow on dark/white colors and it usually disappears but now it comes back for very long periods of time. I've done research and its come down to the LVDS cable. So, what are the steps to replacing an LVDS cable in my 32" Vizio HDTV?
  • 11,361 Answers
Usually if the LVDS cable between the main board and the T-CON board is bad, you will loose one of the three color signals, you may have thermal problem with the T-CON board. I would run the TV with the back open to see if it will take longer for the problem to appear, or get a can of freeze spray for electronic troubleshooting and cool down the T-CON board (board is under the metal shield that you will have to remove to get to all the cables, I would remove the shield and put the screws back in to keep the T-CON board in place).
The TV as shown in my album has bad T-CON board, the pictures get pixelated and scrambled after about 1/2 hour, I was using a small fan to keep it cool until I finally found a replacement T-CON board. Bad LVDS driver IC on the main board can also be the problem. Right now we need to find out if it is heat related problem or not.
http://s807.photobucket.com/albums/yy352/budm/VIZIO%20L32HDTV10A/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 31, 2010
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
See page 8 here:
http://cdn.vizio.com/documents/downloads/hdtv/M550SV/991UG_M420-470-550SV.pdf
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Nov 25, 2014 | Vizio Televison & Video
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
We have a video cable that has red,white,yellow,plug ins can they be pluged in to red,blue,green.37in.vizio LC HDTV E370VL
Yes, this will usually still transmit the Component Video signal (make sure you match colors). However you will still need a white/red to provide Audio.
Jan 23, 2011 | Televison & Video
There is a green tint to my screen. Seems to be more evident in dark shows and on shadows.
Pull the front speaker grille off and remove the access panel. In the customer menu turn the color off so you have a black and white picture. get a flashlight and adjust the screen controls for the red, green and blue tubes until you get a nice black and white picture. then turn the color back up.
May 26, 2009 | Hitachi 51F59 51" HDTV Projection...
Red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
May 21, 2009 | Philips 42PF5331 42 in. Plasma Television
Right half of the screen mostly green and red with vertical strip
It sound like there is a problem with the mainboard. What is the model number of the TV?
Feb 05, 2009 | Vizio GV42L 42 in. LCD Television
Color on vizio 37" lcd
I would recommend a Main board replacement.
Mar 04, 2008 | Vizio L32 32 in. LCD HDTV
JVC projection tv
Mike, convergence adjustments are in your menu, usually under "video" settings. You have to adjust red & blue onto the green, when you`ve done it correctly the "cross" will be pure white, if you cannot move either of the colors left, right, & up, down then the convergence IC`s have failed and will have to be replaced, hope this answers your question, BMW Rider
Dec 30, 2007 | JVC AV-56WP74 56" Rear Projection...
Vizio P4 Plasma green blotches
The same thing happened to me Twice!. First time it was under warranty. Now it it out and Vizio has not interest in helping me. The first time the repair man changed the motherboard, which worked for about a year. Looks like I will be buying a new TV soon, but certainly NOT a Vizio, they are junk
Anyone out there know how much a motherboard costs?
Dec 27, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 32 in. LCD HDTV Logo
725 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
