Question about Vizio 42 in. LCD TV
The TV blacks out every few minutes for just a few seconds at at time. Sometimes more often than others. At first I thought it might be the satelite provider, but the other TVs do not have the same problem.
    Scholar:
  • 83 Answers
Do you have a DVD or Blu-Ray player? If so does it happen with those units as well? Don't you need an individual satellite receiver per tv? You need to isolate if it's a TV issue or satellite receiver first.
Posted on Dec 31, 2010
I'm not sure if this is a TV problem or a satelite problem. We removed the HDMI cable from our 32' Dynex flatscreen for a few minutes, re-connected it and now the TV says "Perform Channel Auto...
Seu problema parece ser do receptor de sinais via satelite. Programa?ao de canais no receptor de satelite; Verifique se seu cartao (chip card) esta bem conectado.
Dec 13, 2010 | Dynex Televison & Video
Samsung DLP TV shows green color where color should be black
This could be your video board going bad where your input cables are connected --OR-- the color wheel going bad. Hard to tell without a photo or reference though. Try swapping the cables first... and listen for any winding or whirring sounds.
Feb 04, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
Black box covers television picture
called a TV repair store, got info over the phone for no charge and the TV is now as good as new. You should tell folks about the charge straight up, I wouldn't mind paying for a service but think you should advise at the onset.
Jan 26, 2009 | Televison & Video
Older TV keeps going to static
Without seeing it I would suspect a bad connection on the main board. As the board heats up the board expands and as it cools in contracts opening and closing a crack in the board. Sometimes a crack or bad solder joint both are sometimes hard to find and it is a lot of solder and wait and see.I have had some luck by tapping on the board with an insulated handel of a nut driver,.. the tv on and watching for any change. If i tapped around the board some areas were more sensitive than others. I then soldered that area. I would tap around again if the set did not react I assume the problem fixed
Jul 19, 2008 | Philips Magnavox 27MS343S 27" TV
Black Squares on the Screen
this kind of problem is normally do of bad cable box or sat
Apr 05, 2008 | Vizio L32 32 in. LCD HDTV
Samsung HLR5067W
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
Nov 16, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
Auto Scanning
Try unplugging it for 2 minutes then se what happens. Make sure that none of the buttons on the TV or remote contol are stuck (especialy if remote is near TV).
Feb 06, 2007 | Audiovox FP1510 15 in. LCD Television
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
142 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
