Question about Kenmore KCM12 Coffee Maker
Kenmore Elite Automatic Coffee/Espresso Machine - Our very expensive and automatic machine won't recognize that the water reservoir is full and won't draw the water in to make a cup of coffee. We've descaled the machine and it was during this process that it failed to draw water. Please help. I need my coffee.
The Machine
  • 788 Answers
SOURCE: I have a Krup Orchestro
When you ran the cleaning cycle did you use the Krups cleaning tabs?
Posted on May 21, 2008
  • 18 Answers
SOURCE: clogged up filter
i'm not familiar with this machine but i think most espresso/capuccino machines' brewhead screen (that's what i call the screen your concerned about) are held in place by a screw in the middle. with machine unplugged & cooled down, remove the screw and take out the screen. if the buildup is really bad, you can scrub as much off as possible w/ hot water & soap, then hold it up between your face and a light (see light thru the holes?) any stubborn holes can be cleared with a pen or needle; you may need to wiggle the needle/pen inside each hole to clear it fully; this is time consuming so you may elect to use a decalcifier (i use 1/2 water and 1/2 lemon juice concentrate-pulp-free, in a small container w/ brew-head screen overnight, then scrub real well & wash again next am). hope this helps!
Posted on Jan 11, 2009
SOURCE: Need gasket for Alessi 6 cup stove top espresso coffee maker
I have a Elevation Espresso Coffee Maker it worked fine until today when it stopped heating the water. Any help would be great.
Regards
frank
Posted on May 31, 2009
  • 3 Answers
SOURCE: Kenmore replacement carafe
had the same thing happen when my carafe broke. Mine is 238.69328 which is the black coffee maker. The simple solution is to head to Walmart and buy the GE replacement carafe. It's the 12 cup capacity one #169164. The box has 169180 on the bottom and it works like the old one and looks just as good no matter what color your coffee pot is. The cost-about $10.
Posted on Sep 17, 2009
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
I have a 2009 Faema Smart S-2, 2 group semi automatic coffee machine. Is it possible to convert it to an automatic coffee machine?
First, I am NOT a Faema repairman, Though I've worked on some Faemas, and similar espresso machines.
** Your question is a bit vague so I will try to provide info.
The 'semi-automatic' means you don't have to watch the brewing of the coffee. The machine will 'Dose' out a per-determined amount of water through the portafilter. Manual machines require to operator to turn water on and off to dose. Full automatic will grind the beans, measure and pack the coffee, then brew the coffee with water. Some have the option to froth and dispense milk directly into the cup. The industry usually refers these machines as 'Super-Automatics' They are very expensive and are designed for untrained personnel (not a Barista) to make coffee. There are a number of Home use machines now that provide a similar function but can only produce a cup for personal use and not multiple cups.
** I have come across automatic milk steamer and frother. This can be a simple cappuccino attachment to your steam tip. More updated version have an auto-frother that replaces the steam wand and will do a fair job (IF THEY ARE KEPT CLEAN!). Some machines have modified steam wands with sensor probe that will measure the milk temperature and shut off the steam when heated to set point. You will find all these features handy at first as it gets a novice worker quickly up to speed to produce product. But once they get the proper Barista training, most will not use these features as it's generally faster to produce orders the standard way. (also a good Barista will always present a professional looking cup!)
** I've noted that repeat customers appreciate the effort that goes into a properly brewed cup of coffee. Otherwise we would all go to a coffee vending machine (with instant coffee, Yuk!)
Aloha! youtube; ukeboy57
Dec 21, 2017 | Faema Coffee Makers & Espresso Machines
I need help understanding how to descale delonghi expresso machine
hi Kathy.
see if this helps you out.
For machines without an automatic descaling cycle:
  1. Dissolve the descaling agent into a full reservoir.
  2. Pull the solution into your boiler by running about a cup of water out of your steam wand. ...
  3. Turn off the machine and let sit for 20 minutes. ...
  4. After 20 minutes, run about 1/2 of the reservoir out of the steam wand.
How to Descale Home Espresso Machine
or try this link.
how to descale delonghi espresso machine Google Search
Dec 12, 2017 | DeLonghi Coffee Makers & Espresso Machines
The coffee comes out very slowly and does not give me a short coffee.
Try putting vinegar in the water reservoir and run the cycle a few times.
Dec 12, 2014 | Spidem Trevi Automatic Espresso Machine
Does not recognize there is water to brew
Ensure that the water reservoir is seated properly in the machine, behind the plastic clips at the top and straight down into the base.
Mar 18, 2014 | Keurig Elite B40 Coffee Maker
Tube that takes water from reservoir into mechanism is clogged somewhere inside machine; can't even blow air from water-reservoir into machine. When attempting to use, only small amt. of water (hot) gets...
If at least some water comes out, do you get water from the hot water cycle, if yes then adjust the grind on your coffee and or remove the brew unit, I am assume you have and automatic espresso machine, if not then remove the screw and shower screen and clean.
Sep 20, 2010 | Starbucks Coffee Makers & Espresso...
I accidentally started running the machine without the water and now it's not working.
The pump will **** air, but just fill the water reservoir and run the machine 3-4 times and it will be ok.
Jan 03, 2010 | Nespresso C100B Essenza Single-Serve...
Bunn Automatic Coffee Maker
make sure that the machine is turned on on the left side in the back.  this machine needs an hour or so to warm up the reservoir of water built in to the machine.  try again.  this machine should stay on all the time.
Aug 14, 2008 | Bunn A10 Coffee Maker
Machine kaput
Try turning on the frothing wand ... the water light should reset once the water has come through.
Mar 14, 2008 | Gaggia Super Automatic Espresso Machine...
Kenmore KCM12 Coffee Maker Logo
106 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
Jude24
ray gallant
 steve
steve
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
