Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Would like to connect a fax but only port 1 or (tel 1) port 2 does not work, should i send back to comcast or reset modem
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 143 Answers
There is nothing wrong with your modem. Comcast charges extra for a second line. Depending on your model of fax machine, there should be both an input ond an output on the back of the fax machine. Plug the fax machine into line 1 on the modem. Then, plug your phone into the input on the back of the fax machine. If you fax does not have both in and out, then you can purchase a "Y" phone line adapter from your local electronics store.
ps. VoIP is a digital line... Facsimiles are analog signals... Sending analog signals over digital lines is not recomended. If you are wondering "why?" (and understand tech jargon) VoIP is sent via UDP, which is a connectionless protocol (does not retransmit dropped packets) Fax machines use TCP, which does resend dropped packets. This variance in Qualiy of Service sometimes cases strange activity such as both lines (sending and receiving) dropping connections, faxes taking a long time to transmit (due to constant resending loops), etc. It does work... kind of. I would just not assume that faxes made it to their destination until it gets confirmed.
Posted on Dec 31, 2010
  • 591 Answers
First check with your ISP (Internet Service Provider) to see if it's just a setting in the modem they can activate the port for your FAX
have fun!
I got a Netgear wireless router from comcast I did the instructions on the cd, after it was detecting my connection it said that I have a static ip, I talked to comcast and said that is not right that I...
1.call comcast and ask them to put your modem on bridge mode.
2. Once the modem is on bridge mo the internet light will turn OFF
3. connect your comcast modem using the Ethernet cord to the Internet port at the back of your netgear router.
4. connect another ethernet cable from port number 1 from the back of your router and the other end should be connected at the back of your computer.
5. Then go to this website for the instruction to configure your netgear router. it includes screenshots as well for better understanding.
ftp://downloads.netgear.com/files/rp614v3_setup_manual.pdf
Sep 08, 2011 | Computers & Internet
I have a RCa broadband modem from Comcast. I want to connect my computer Fax card to it. IS that ok? How do I do it? Just connecthe telephone cable from the port at the back of the computer to the RCA...
Yes it is perfectly OK. Remember that a fax essentially works as a phone, so you would run a line from the RCA modem to your fax card, then from the fax card to your telephone. In this scenario you would have to accept your faxes manually though.
Mar 16, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have a hp officejet all-in-one and I can't get the fax function to work. I have comcast digital voice with a rca modem. The fax machine dials and the line goes dead. If I call the fax number on the...
Since you have a DSL ( Digital Subscribers Line ), the HP Fax printer works on Analogue Signals.
To make the GP Printer work on Digital line, First step you can do is to Reduce the Fax Speed from Fast/Medium to SLOW.
To Do so, Click on Setup button on printer front panel - Choose Fax Settings - Choose Fax Speed - Set it to Slow and try to fax
If this does not work, you will have to connect a DSL Filter ( this is a 2 way port - 1 port for Digital line and another for Analogue )
You will have to connect this Filter to DSL Phone line - in the IN port and from the Analugoue Port - Connect Phone cable to Printer Line 1 EXTN Port at back of Printer
Jul 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Need manual for connecting fax to phone line and computer
Simple:
* one telephone-wire from wall-outlet to port on FAX labelled "line" or "telco";
* one telephone-wire from port labelled "phone" (or an icon of a telephone) to the port on your computer's modem labelled "tel" or "telco" (if your modem has more than just one port).
So, "incoming" telephone-calls go the FAX, to be "answered" by the FAX, while "outgoing" dial-up-Internet connections from your computer's modem "pass-through" the FAX, and to to the wall-port, and further along to the Internet Service Provider.
Jun 15, 2010 | HP DESKJET PRINTER, HP OR COMPATIBLE
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
Connecting internet to the playstation 3
Before connecting the ethernet cable to the back of your Playstaion3 hold the modem reset button for 15 seconds, when 15 secs are up connect the ethernet cable to your ps3 system, wait until tour Comcast High Speed Internet goes online again (all the lights are showing fine) then try setting up your Playstation connection settings again, it might work since now you have reseted your modem and the modem will send information to new device, I hope this information works for you, :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
Can't get the fax to work. It WAS working before.....
follow this simple steps:
1 .Connect the phone cable that came with the printer to the back of your modem to the port that says tele 1.
2 . connect the other end of the phone cable to the port on the printer that says "1-line"
3. connect the phone cable or cord that came with your telephone line to the back of the printer port that says "2-EXT" and the other end to the back of your telephone ..
This should solve the problem..best of luck
Mar 26, 2009 | HP Officejet 7210 All-In-One InkJet...
When I try to fax I get a message that there is no dial tone but I am using a modem from comcast. I contacted comcast and was told to contact lexmark
1) Take a regular phone and test the line
2) Check the status of your modem in your computer
Start >> Control Panel >> Modem
Verify if oyur modem is giving to you a response
3) Check if the cables has been connected into the right port (line in - line out)
Oct 29, 2008 | Lexmark Office Equipment & Supplies
SET UP
CONNECT POWER CODE TO FAX
ALSO CONNECT TELEPHONE LINE TO ITS POSITION.
THEN RESET YOUR FAX TO DEFAULT SETTINGS
SET AUTO RECEVING .
ALSO IF U HAVE PC WITH MODEM U CAN SEND AND RECEIVE FAX FROM IT.
IF U NEEDD ASK ME.
BYE
Mar 24, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
210 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
