Question about Dryers
Clothes take too long to dry. Vent and filters cleaned. Gas flame keeps going off and then on again but never really gets hot
  • 1 more comment
  • sjones942 Jan 02, 2011
    I can observe the igniter get hot and then the gas will will flow, but after about 1 minute the gas will shut off. I am guessing it must be one of the thermostats.
    It draws 2.7 when glowing. Then .03 once the gas starts burning.
  • sjones942 Jan 05, 2011
    Problem solved
  • 1,998 Answers
Have you tried checking the ignitor in your dryer ? a typical dryer ignitor for a gas dryer usually draws between 3-3.3 ampers if you take and connect a voltage meter or a multimeter around one of the wires going to the ignitor you would be able to see if it is between this range what actually happens if it is lower then 3 is the gas does not ignite in time so your dryer never reaches the tempreture that its trying to maintain what happens inside the dryer is it reaches the factory preset tempreture depending on what make and model you have the high tempreture of a dryer is between 150 and 190 for a hi and 120 -145 for the low inside your unit you also have two relays a hi thermostat relay which shuts off the gas when the tempreture reaches the preset level and a low thermostat relay which turns on the gas in which the ignitor is supposed to kick on and light the gas but if it is to weak it will not and will take alot longer for it to light If you have any further questions please message me back. Also please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
p.s about the cheapest place to buy any appliance part is www.marcone.com go under contact us there is a 1800 number and they ship anywhere in the world Thanks again
Posted on Dec 31, 2010
  • 2 more comments
  • Rick Ead
    Rick Ead Jan 02, 2011
    did you do the ampere test to the ignitor if the ignitor was drawing 2-2.9 you would still see the bar get red you have to be able to do the actual test or call a technician if you are unable Thanks again Rick
  • Rick Ead
    replace the ignitor
  • Rick Ead
    also please remember to rank how this opinion has helped 4 thumbs up are what i personally try for on all chats thanks again Rick
  • Rick Ead
    Rick Ead Jan 05, 2011
    hello could you please rank this chat with 4 thumbs up i try to acheive 4 thumbs for all chats Thanks again Rick and Happy New Year
My lg gas dryer will run alright just will not dry clothes.The flame will ignite for maybe 10 seconds or so and then shuts off.It keeps repeating. I know it sounds like my flame sensor needs cleaned.
I would check the vent and be sure it is open and free of lint. That would be the easiest thing to check. If you have the flexible white duct replace it, it is a lint trap.
Apr 02, 2015 | LG Dryers
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
I have replaced radiant flame sensor, high limit thermostar, cycling thermostat, coil kit, and blower wheel on maytag dryer ldg9206aae, and still it takes forever to dry and is not hot enough.
if the flame is lighting like it should and you changed out all those parts did you clean out the lint filter duct and clean out the vent line?try removing the vent line from the back of the dryer and run it,if the flame stays on longer and it heats you have a blocked vent line,if the air can't move and that's all a dryer does the clothes can't dry
Apr 10, 2013 | Dryers
Not drying clothes
send model number so i can see what you have,is it gas or electric?if it's gas you could have bad gas coils,the dryer will have heat for the first 15 to 30 minutes then when the coils heat up they fail,when they cool down they will work again,also when was the last time you took the dryer apart and cleaned it out and blew out the vent line.if there's lint in the duct where the lint filter slides into or a blocked vent line the air can't move and your clothes won't dry,if the vent line is long you can remove it from the back of dryer and blow it out with a leaf blower,you can remove the line and run the dryer,if the clothes dry on time then you know the line has lint in it.Http://www.youtube.com/watch?v=2bVoelV7M7Y watch video if filter is on top watch this video http://www.youtube.com/watch?v=xGIG8Wo5-N4. this will show you how to take your dryer apart to clean it out.if you send the model number i can help you better,if it is gas there should be a plastic cap on the front panel down low that you can pop off,start the dryer and look inside,if the flame lights that's good,you should hear a couple of clicks as it's lighting,after like 15 minutes check it,if you see the ignitor glow orange and then go out without the flame lighting then you have bad gas coils located on top of the gas valve,very easy to do.let me know what you find,send the model number and i can look up the parts you will need.
Mar 18, 2013 | Kenmore Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Lgq9858pw dryer. Clothes would come out damp and cold. I replaced 2 thermostats (?) in the rear of the unit, located on the heat shield. The clothes now come out warm, not hot, but still damp. Any ideas?
if you popped the high limit thermostat that usuallt pops when the dryer needs to be cleaned out.pull out the lint filter,unplug the dryer,remove the two phillips screws in front of the filter,go in the back,remove the vent line remove the back panel and remove the duct that the lint filter slides into and clean it out,if you can't remove the duct push it to the right and vac out the blower wheel and pull the duct out towards you so you can get the vac into the duct to clean it,also if you have a brush you can brush all the lint down to the bottom and vac it up.if the vent line is a long run to the outside i use a leaf blower to blow out the vent line,go outside first and make sure the vent is clear so the lint will blow outside.one or both of these sound like it's blocked with lint or you can also have bad gas coils.the coils work for the first 15 to 30 minutes and stop working when they heat up.after they cool down they will work again until they get hot.you can start the dryer,pull off the plastic cover on the left side so you can see the flame ignite,watch the flame lite,after 15 to 30 minutes go back and look into the hole,if the flame isn't liting you know the coils are failing.easy fix,unplug the dryer,the coils are on top of the gas valve,remove the two pillips screws,remove the cover and replace the coils,part number 279834 and they are around 20 dollars,you get both coils instead of getting them separate.you should clean the dryer once every year so the dryer runs like it should,clothes drying on time,your parts will last longer and you don't have to worry about any lint fires
May 04, 2011 | Dryers
It takes 2 or 3 cycles to dry clthes, has been going on for some time
That's typically an indication that air is not moving through the dryer. Check the dryer screen, make certain that it's clean. You may need to remove the back and clean out any dryer lint. If the dryer vent is long, it may have filled up with lint, restricting air flow. You may need someone to clean that for you.
Feb 06, 2011 | Dryers
I have a kenmore gas dryer 110 it doesnt dry the clothes the burner goes on then of stays worm not hot check the fuse its ok the igniter works also dont know what else to check
if the flame is liting but stops after 15 to 30 minutes you have bad gas coils.if the flame is liting and clothes are not drying you have to clean out the dryer and the vent line.remove the vent line,if it's a long run to the outside i use a leaf blower to blow out the line,check the outside and make sure nothing is blocking the vent like a screen or cage,if there is remove it and don't put it back after you blow out the line,then clean out the duct that the lint filter slides into,if filter is on top the duct is in the back,remove the front panel and vac out all the lint in the cabinet where the motor is.number one problem with dryers is lint build up,all a dryer does is move air,if it's clogged with lint your gonna have problems.send full model number next time and let me know how you make out,if you need more help let me know
Jan 22, 2011 | Kenmore 74602 Gas Dryer
My maytag dryer is taking more time than usual to dry up clothing. Can anyone help identifying the problem and possible solution? Thank
you have to clean out the dryer and the vent line,unplug the dryer,remove the lint filter and then you need to remove and clean out the duct that the filter slides into,then vac out the cabinet where the motor is,go outside and check the vent,make sure it's clear,then remove the vent line from the back of the dryer,if it's a long vent line i use a leaf blower to blow out the line.also if you have a gas dryer,check it after 15 to 30 minutes to make sure the flame is still igniting,if the gas coils are bad they will fail when they heat up,when they heat up the flame doesn't lite until the coils cool down and your clothes will be warm but wet.you should clean the dryer once a year if it's gas and once every two years if it's electric,gas dryers have an open flame and the lint can catch fire easier than electric dryers,do this and your clothes will dry on time,no fires,save energy and money on your bill.good luck
Oct 10, 2010 | Maytag Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
