Question about Lincoln Electric Century Portable Plasma Cutter - 25 Amp # 82021
I have a lincoln SP-170T welding machine, and I would like to know if I can get a manual for this machine. mhallidaym@bigpond.com. thankyou Matt
Go to lincolnelectric.com - quick links - operators manuals - search by the code number of machine - download and print. Parts manuals are available for some models also
Posted on Feb 15, 2011
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 70 Answers
Here's a link to the SP170-T manual PDF on the Lincoln Electric Site
http://www.lincolnelectric.com/assets/servicenavigator-public/lincoln3/im710.pdf
Posted on Aug 24, 2014
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
How do you find the defrost timer on custom imperial model number FPCI-170T-7.
Hey Robert Bouie, thank you for your post!
I understand that you are searching for the defrost timer inside of your Frigidaire imperial, FPCI-170T-7. I have researched the model number provided and I show that it is an older model. In order to provide you proper location of your defrost timer I would seek assistance from a professional. I hope this is helpful. -Matt
Oct 01, 2014 | Frigidaire Refrigerators
I have a lincoln sp-100 welder and despite having a good ground the weld quality is just not there. Any help is appreciated
Let's troubleshoot this one:
1) Make sure you have the right polarity for the wire you are using: Innershield wire (no gas) ground clamp must be on the + side. Solid Wire (gas use) ground clamp to negative side.
2) If gas is used: Mild steel welding requires Argon/CO2 mix 75/25 or 90/10. Using pure CO2 you will create a lot of sparks and a lot of fumes. Stainless Steel welding requires a Trimix gas of Argon/Helium and CO2. Aluminum Welding requires pure argon. Any use of gas requires a steady gas flow of no more than 25 SCFH. If you use more than that or less you will find porosity on the welding.
3) Your work piece must be cleaned before welding (no grease, dirt or paint).
4) Check your machine welding chart for wire speed and voltage.
If you still experience problems with welding quality, check you input power voltage, make sure it doesn't fluctuate.
Goooooood Luck.
Aug 30, 2011 | Lincoln Mig Welder Trigger Switch Magnum...
Wiring diagrams for lincoln sa-200 F-163 welding machine
try Westermans - used welding machines supplier. They stock the best brands like Lincoln, ESAB, Kemppi and Fronius. They should also have operator manuals for most machines. email them at welding@westermans.com ask for Craig.
Sep 03, 2010 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Lincoln welding machine
did someone turn the dial while welding?what has happened is the contacts are welded in that postion.I worked on welders for lincoln,hobart,esab and miller as warrenty repair shop.I never was able to dislodge the welded contacts to work smooth agian,you have to buy new dial and probley have tech. put it in.
Mar 13, 2009 | Lincoln AC-225 230V
Hook up
I think I can help you do this, let's start with the general and you can ask questions if we don't cover everything you need.
The HF251D connects to the welding machine using 3 cables, you connect the Electrode terminal on the welding machine (the Lincoln) to the Electrode In terminal inside the HF251. Connect the Work terminal on the Lincoln to the Work In/Out inside the HF251, also connect the work (ground) clamp of your torch to this terminal. Be careful to select the correct size cables for the maximum current you intend to weld with.
The 3rd cable is the gray 14 pin round control cable that comes out the back of the HF251, it needs to be plugged into your Lincolns RMT14 socket. You'll also need to make sure that the Lincoln is set for remote control, this is usually a switch on the front panel. I'm pretty sure that the remote control cables have a standard pin layout, but we can check this by comparing the specs in both owners manuals.
After that you connect the torch and gas bottle to the HF251, start the Lincoln, and TIG weld until you're happy.
I've got a manual for the HF251 and can get a shop manual for it if we need it. What I'm not sure about is your Lincoln - what model is it exactly?
regards,
Carl
Dec 10, 2008 | Miller Hf 251D 042388 Tig Hi Freq For...
Lincoln Electric  Century Portable Plasma Cutter - 25 Amp # 82021 Logo
830 people viewed this question
Top Lincoln Electric Welding Tools Experts
Troy
Troy
Level 1 Expert
AZBen
AZBen
ka4iup
ka4iup
Are you a Lincoln Electric Welding Tool Expert? Answer questions, earn points and help others
