Question about Toys
The helicopter is fully charged but its hard to get the chopper and control in sync it takes the shaking of the control for it to catch and start to fly. what is the problem??
    Problem Solver:
  • 4 Answers
Maybe you are on the wrong channel.... A,B or C. It would also be surrounding light. If it's to bright, it will interfere with your signal. Fly under a light and crash. It sounds like you are getting interference of some kind.
Posted on Dec 31, 2010
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
My Gyro s107g helicopter won't connect to the remote. It just sits there not moving or any lights turning on.
It sounds like the two are not compatable. In other words the freakwinsy of the plane is not the same as the controller. THEY MUST MATCH. You may find the numbers on the back of the controller and where the batteries go in the chopper. If the numbers do not match, take it back to the store, and get one that does. Sorry for the spelling
Jan 13, 2015 | Syma S107G 3CH RC Helicopter RTF w/ Gyro...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
I have an air shark II and have no clue how to charge it ! there is a little wire that comes out of the controller and i plug it in and it just flashes red i let it charge for awhile and it still flashes...
The AirShark II has two ways to charge it. First you can plug in the USB cable into the chopper and then into your computer. The charging takes about 50 min. The second way is to take the little connector from the remote control and plug that into the chopper. The on button should be on the remote and the off button should be on the chopper. This also takes approx. 50 min.
Call us today for Virus Removal or other computer related issues
http://computech-ct.com
203-307-0452
Dec 15, 2012 | Cobra R/C 3 Channel Big Shark Helicopter
Hi, the issue I am facing is that my remote is not able to connect to the helicopter. Earlier when I used to put the battery the light used to blink, now as soon as I switch on the remote it just does...
Helicopter should be powered off when charging. After fully charged (charging light as bright as it gets) and given 10 minutes to cool after charging, turn on helicopter first and place on level surface, this allows gyroscopes to sync up. Then, after making sure the main rotor control (left joystick) is all the way down, turn on controller, and quickly push left joystick all the way up (just until the blades move) and back down. This will link them. Also, make sure the antenna is still wrapped around the landing strut and not contacting any metal on the craft. And of course, good batteries in the remote, and ALWAYS let helicopter battery cool for 10 minutes after charging AND after flying. Also, NEVER fully drain battery, as soon as you cannot maintain altitude, land and power off. Fully discharging a Li/Po battery will weaken it severely, and sometimes kill it.
Please let me know if this helps, I love Syma helicopters, but they can be tricky sometimes...
r
Sep 04, 2011 | SYMA Toys industrial Syma S032 Ready to...
Can't figure out how to change frequency on the S107 copter itself (not the controller). Can someone advise. Thx
Found this for you.
it appears that the helicopter dynamically configures the control channel upon first detection of a signal from a controller. So, If you 1) turn off the helicopter, then 2) turn on the controller, then 3) select the desired channel on the controller, then 4) turn the helicopter back on, then 5) hold the throttle down on the controller, the helicopter will start up (after a slight delay) and be controlled via the new channel.
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Radio...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
4) Power on remote.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
hope this helps,
r
S032 won't fly higher than 0.5m. and for a few secondes. I bought 2 Syma S032 helicopters whith 3 lipo's. The first 3 a 4 times both choppers flow verywell. I have charged the batterie's so as told in the...
1) Ensure you're fully charging. Indicator light on charging unit should NOT get brighter at all when you unplug the helicopter. If it does, then plug helicopter back into charger until light stays the same when you unplug. Note: If you're charging with a usb charger and are using a laptop or the front side data port on your desktop, these may take several hours to fully charge as they are usb 2.0 and do not carry the full 5 volt dc charge. Use powered usb (3.0) on back of desktop, or get a usb/ac adapter. Normal charge time approximately 1 hour. Go by the light, though.
2) Don't run them dead. As soon as you can no longer maintain altitude, land and turn off helicopter. Fully discharging a Li/Po battery (particularly when it's new) will cripple it's ability to hold a charge, and can ruin them.
hope this helps
r
Nov 01, 2010 | SYMA Toys industrial Syma S032 Ready to...
Shuttle 9094 r/c helicopter spinning on take-off
usually trim adjustments are on the controller... not on the vehicle itself.
a potentiometer os a fancy word for dial adjustment. It wont be a metal screw, but probably a metal square with a plastic looking slot that can be turned. usually white or blue plastic
Dec 22, 2008 | Shuttle 9094 Emax Remote Control...
Toys Logo
51 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
