Question about Nokia 6230
Nokia 6230 my cell is not recieving from blue tooth & memory is empty but every picture or ring tone which one i try to download on display message memory is not enough memory full
  • 108 Answers
ONCE U REMOVE THE MEMORY CARD AND INSERT AGIAN AND CPY UR FILES EVEN IT IS EMPTY AND U SHOULD COPY THE FILES WITH OUT ANY OTHER FOLDERS OR U SHOULD GO AND CHECK OUT UR PHONE MEMORY PINS OK RATE ME WITH 100%
Posted on May 27, 2009
  • 983 Answers
This happens due to the firmware problem (this is may be due to virus present in phone)....
try giving the restore factory settings in your phone ...
if you still persist the problem then you just update the firmware of the phone that solves your problem ....
you can update the firmware with the normal datacable only ...
you can update to the latest firmware for your phone from the software called" Nokia Software Updater "...
you can download this for free from the website of nokia directly given below :
http://europe.nokia.com/A4579163
(your pc must be connected to net to download the latest firmware)
but remember dont disconnect the cell while updating the firmware is in process if you do so your phone will be severely damaged you can never use your phone ...
even the manufacture can t help with this if you interrupted during the firmware update ....
after you update the firmware all your problems will be solved ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Posted on Jul 13, 2008
Ineed a solution
Posted on Jun 05, 2009
I can not hear the ring tone of my Nokia 6230
your phones buzzer need to replace ,if you want to know the location of your 6230 buzzer just comment and i send to you the screenshot..thanks
Jun 12, 2010 | Nokia 6230
Blue Tooth recieving error ''operation failed'' in Nokia 6233
go to bluetooth settings and put save in memory card
May 14, 2010 | Nokia 6233 Cellular Phone
Cant find where my ringo tones went!!
its get stored in your phone memory by default,or check your message box
Feb 19, 2010 | Samsung Exclaim M550 Cell Phone
My nokia 1661 wont display names when i recieve text!!!
+91 is code for india ,so any national no. is preceded by +91
Aug 06, 2009 | Nokia 6230
How do i get the volume up
YES U CAN DOFROM THE SETTINGS GO TO THE RING TUONES AND SCROOL DOWN THE KEY AND CHANGE THE RINGING VOLUM AND U SHOULD OFF UR VIBRATIONS OK BYE U CAN GET U AUTO MATTI CALY
Apr 09, 2009 | Nokia 6230
Problem with Nokia N72 memory
korakbc switch off your phone.after your hold keys "call button,star button and three button"hold and switch on your phone.
Mar 05, 2009 | Nokia N72 Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
MY NOIKA 6230 DOESNT ACCEPT THEMES AND PICTURES FROM BLUETOOTH
well first check memory status because maybe you memory is full so the file cant be recieved
Feb 10, 2009 | Nokia 6230
Mpe ringtones not playing. getting not allowed
The mp3 ring tones must be less than 150Kb "try lower the quality"
Jan 10, 2009 | Samsung SGH-M310 BLACK Cellular Phone
Low Memory Status
hello abcfactor2003 i agree that you have lot of space in memory card but have you checked the phone memory?When you recieve any blueetooth message it is recieved in message box have you checked that in message box you are using phone or a card with you problem i probably think that you are using phone memory in message so what you do is open message goto option than setting than others than select memory in use select memory card now you can recieve songs videos as much as memory card is free (Regards Paljor Lama)
Jul 26, 2008 | Nokia N72 Cellular Phone
Nokia 6230 Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
