Clothes are still heavy with water after the spin cycle.
  • Washing Mach... Master
  • 17,129 Answers
Make sure that the washer is running at the desired spin RPM. if not check for failure of the belt, fault in the brake pad holding on to reduce the spin or a failure of the motor or the motor capacitor.
Only a good spin RPM will ensure that the clothes are dry with the high speed motion.
SO check this out with a good inspection of the spindle and motor drive.
Wishing you a Happy New Year.
Posted on Dec 31, 2010
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Clothes are still water logged after cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
From Repairclinic
Oct 24, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
