Question about Germ Guardian Humidifiers
Germ guardian humidifier won't turn on after refill
2 Suggested Answers
SOURCE: Hi, I was cleaning my
For replacement parts contacting the manufacturer of the humidifier would be the best thing to do. They know what parts can be replaced and if they have service repair facilities or if you would need to work directly with the company. Germ Guardian website is www.germguardian.com. Toll free 1-866-603-5900.
Posted on Apr 12, 2011
Wont come on
no power on---check may be have a fuse inside
May 31, 2014 | Pure Guardian H1500 55-Hour Midsize...
Water refill light prevents unit from working. Tank is filled . Unit has been cleaned
Your problem is most likely a damaged Ultrasonic Disk (sensor).
If your product has not been used for a while, this piece was most likely damaged if it wasn't properly cleaned before storing. Cleaning well sometimes isn't even enough for this sensitive unit.
Unfortunately, there is no way to get this part, even though it is easily removed and could be easily replaced. Bad PR on the manufacturer's part. Your only solution is to send it for repair (if under warranty, you just pay shipping, if not, you pay shipping and $30) or to buy a different brand. You would think for as expensive as these machines are, the manufacturer would have a better solution to this extremely common problem.
Jan 13, 2014 | Germ Guardian H-3000 Ultra-Sonic...
Where do I find manual for germgaurdian H3000 humidifier.
http://www.guardiantechnologies.com/product-instruction-manuals/
Germguaridan website.
This manual can be found under discontinued models. This was most likely discontinued because it is very sensitive and quits working too soon because of the ultrasonic sensor.
Dec 10, 2013 | Germ Guardian H-3000 Ultra-Sonic...
Germ guardian h3000 not blowing air
I have a Vicks, similar, and it recomends a little table salt in the water to create a mist, read your manual and see if this helps. Don't go overboard on the salt, or you'll have old faithful instead of a mist!
Apr 07, 2013 | Germ Guardian H3000 Humidifier
Hi, I was cleaning my H3010 Germ Guardian Humidified and damaged the small round part with 2 wires (JR707). It is the part where the water mist comes from. Is there a way to buy this small thing ot...
Apr 09, 2011 | Germ Guardian Humidifiers
Humidifier Leaking over floor, not retaining water, excess bubles
My humidifier is leaking. I is a Vicks V3900 Germ Free Cool Mist Humidifier. How do I solve this problem
Feb 09, 2010 | Vicks Humidifiers
Have a warm air Honeywell humidifier. The "refill/restart" button is permanently on even if I refill the humidifier and the humidifier does not want to work now. How do I fix this? It seems a sensor is...
This may be due to one of two things.
1. If you turn the unit off or unplug it when you refill the resevoir, then plugging back in or turning it back on will not automatically reset the refill sensor. You must depress the restart slide switch on the bottom front controls to reset and restart the unit, or.....
2. It the refill light won't clear after refilling the resevoir or following the above step, the most likely cause of the problem is a scaled up heating element, which must then be cleaned.
I just uploaded a copy of the user manual to this site, but if you would like to download it directly, follow this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
Hope this helps!
kcomp1863
Dec 03, 2009 | Honeywell Warm Mist HWM-2030 Humidifier
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Clean/refill light
My Slant Fin humidifier has a floating, ring-shaped magnetic level that isn't replaceable. You can't even tell it's magnetic until you cut off the piece that prevents the white plastic float from rising past a certain point. It turns out that there is a ring-shaped magnet in the float.
I found that the Refill light would go off when I held a strong magnet near the float device.
So, I have suspended the magnet with string from the top of the humidifier outside the humidifier.
Caution: This fix disables the safety feature inherent in the low level shut off. I wonder why the manufacturer uses material that corrodes?
Oct 14, 2007 | Slant Fin Warm Mist GF-350 Humidifier
Humidifiers Logo
341 people viewed this question
Top Germ Guardian Humidifiers Experts
Mack Baxter
Dennis
Are you a Germ Guardian Humidifier Expert? Answer questions, earn points and help others
