Question about Pool & Spa
My spa pump comes on for 10 swconds then shuts of
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Something is causing the pump motor to overheat and shut off to avoid permanent failure.
The motor is likely failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft to see if it is damaged, bent, or the bearings failing or seized.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced.
*All of this assumes this is an older/existing installation that has worked properly in the past and is just now showing signs of failure. If this is a new install look at your line voltage versus the voltage the motor is set to accept. If feeding 115 to a motor wired to be on 230 you will also get the situation you describe.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 01, 2011
I have a Sundance 850 spa that when you switch it on at mains power , runs for 5-10 sec then shuts off. Have message - - - - that comes on display panel
Had a similar problem; the heater was blown. You might want to try disconnecting heater wires (with breaker to spa OFF).
Then see if spa pumps work after turning power on.
I got an after market heater that works great; VERY hard to install while spa is full...but I did it anyway. Good luck.
Feb 22, 2016 | Pool & Spa
I have an "Intex Pure Spa" inflatable spa. It shut itself off. when I push restart it starts up then in about 10 sec an "E" comes up on the screen and it beeps. What can I do to reset and fix the err
Has your problem been resolved?
Please use 'Comment', and inform the forum here of your experience.
What did you do? Did Intex help?
If you are still dealing with this problem, let us know.
If so, and for anyone else with a problem ...
Support Intex
Jan 30, 2015 | Intex Pool & Spa
Aruba spa model1060
bad motor or if it pops breaker disconnect the heater leads remember where they go try it again if it runs bad heater element
Aug 08, 2014 | Qca Spas Majestic Series Aruba Xl Hot Tub
I have a Paradise II, had it installed on 10/06 around March of this year one of the motors for the jets quit. We shut the spa down every summer so we did not have someone come out and look at it. Once we...
If this is under warranty call the manufacturer. If it was purchased at a big chain store like cost-co call them. It is very common for hot tubs that are shut down most of the year to have these problems. The motor shaft seals need to stay wet, but when shut down they are dry. When they go dry they shrink, causing leaks, which will in turn let water leak into the motor housing, which will in turn seize the motor bearings. It is much better once you have it up and running to run it year round, and when not in use, turn down the temperature as well as switching the controls over to "economy" Every spa made in the last 10 years has this setting. It will cost $.25 /day to run like this (about) which is way cheaper than service labor and parts. If you have a good spa tech. he should be able to replace the bearings for $35 each plus one hour labor per pump. If you have a bad spa tech. just pay to replace the pumps or do it yourself.
Oct 08, 2010 | Qca Spas Paradise Hot Tub
QCA spa pump won't shut off
bad multiple speed relay and temp sensor
Apr 03, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
