Question about Kenmore Refrigerators
Our refrigerator isnt getting cold - Kenmore Refrigerators
  • 472 Answers
A few things to start with... the refrigerator actually gets cold from the freezer side. so is the freezer cold and if so is there frost on the back wall? are you sure the compressor is running it is located in the rear on most models and should be heard if it is running. sometimes when a compressor goes out you will here a clicking noise every few minutes which is the relay trying to start. is the fan inside the freezer side running with the door swich pressed with your finger listen inside do you here a fan running.... also make sure the coils are clean on alot of models they are located under unit...need more info...
Posted on Dec 31, 2010
  • Kenmore Master
  • 17,129 Answers
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Wishing you a Happy and Prosperous New Year.
2 Suggested Answers
milten1
  • 1304 Answers
SOURCE: My refrigerator isnt as cold as it should be. The
check your freezer fan, is it working, you may need to hold the door switch in if there is one,
next check your freezer carefuly for frost
then try to see if you can feel air in the refer with the freezer door closed...
Posted on Oct 06, 2009
My fridge isnt getting cold
if the fridge isnt getting cold, and the compressor is running, try to check the amperage of the compressor side, if the amp. lower than normal current, there must be a problem of the refrigerant (leaking) or lose compression. And if the compressor is not running try to check the thermostat, compressor and the relay.
Dec 05, 2010 | Refrigerators
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator isnt as cold as it should be. The freezer works perfect but refrigerator isnt staying as cold.
Oct 05, 2009 | Kenmore Refrigerators
The icemaker will not work
you might need to replace the icemaker or the freezer isnt getting cold enough for the icemaker to operate correctly. if freezer isnt getting cold enought for icemaker to operate correctly you should probably have it checked by a tech. if the icemaker isnt taking water you also could have a bad water valve
Sep 17, 2009 | Refrigerators
Freezer isnt cold
If your freezer isnt getting cold then you will need to find out if your fan and compressor is running. It could be one of them that are bad
Sep 16, 2009 | Whirlpool Refrigerators
My refrigerator/freezer isnt getting cold enough
The problem usually isnt in the freon it usually is in the defrost system located in the freezer.I guess you have got this fixed by now and Im sorry for taking so long to get back to you but I havent used the computer in about four months because of family emerg. if you have any more problems let me know.
Sep 29, 2008 | Kenmore 53092 / 53094 Side by Side...
Refrigerator
I had the same problem with my refridge it is a very bad product at first it worked perfectly fine made everything inside it nice and cold but now it barley gets cold at all ANY HELP on fixing this problem and making it cold again thanks
Jan 03, 2008 | Refrigerators
Refrigerators Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
