Question about Polaroid i1437 Digital Camera
Polaroid i1437 Won't Turn On -Fresh batteries -The lens is fully extended even when off -When turned on, there is a servo motor sound and a beeping -The LED power light flashes slowly -No screen Is there a master reset? Thank you! Clair
melnavz
  • 1226 Answers
SOURCE: MY CAMERA
hello.
Im not an expert in camera however i can suggest you to reset the camera. if not resolve then, the battery connnection failure to connect when the camera boot up. please do a series of check up of the battery connection. if you affraid to do so, the; maybe you can let the repairman do it for you.
melnavz
Posted on Mar 23, 2008
SOURCE: Polaroid i639
Ok, i just had this problem 5 minutes ago because i dropped my camera. I know, very stupid of me! but i was able to fix it myself, and hopefully you can too.
the problem is your lense. The lense being stuck causes the camera to automatically power off. if you can tell where the lense is stuck (you can usually see because it is jammed and lower than the rest, it slants in that direction) you may be able to pull it back out without damaging the camera. i just did this and i was so relieved!
Posted on May 28, 2008
SOURCE: my Polaroid i533 digicam won't turn on
it's not working.. you think polaroid is stupid?
Posted on Nov 21, 2008
DUMPLINS559
SOURCE: i733 Polaroid camera will not turn on
well I HAD THE SAME PROBLEM ALL I GOT WAS A BLACK SCREEN & 3 BEEPS,SO GOT A LETTER OPENER AND STUCK IT IN THE SPACE BETWEEN THE ZOOM LENS A FEW TIME VERY CAREFUL PUSHING DOWN THE POWER BUTTON AT THE SAME TIME AFTER A FEW TIMES THE LENS BECAME UNSTUCK..JUST JIGGLE IT A ROUND A LITTLE BACK AND FORTH WITH A LITTLE FORCE.I HOPE YOUR CAMERA WILL START TO WORK AGAIN LIKE MINE DID.
Posted on Feb 05, 2009
  • 11967 Answers
SOURCE: Polaroid i1035 powers on briefly then shuts down
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 18, 2009
My polaroid i1437 light will blink, but won't come on
Hard to tell but possibly a battery problem, There could be many reasons some of which you will not want to hear. need more info.
Jan 21, 2013 | Polaroid i1437 Digital Camera
I dropped my camera and it is just frozen can't get any response idin't drop it that hard it's a Polaroid I1437 digital
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a video summary of the steps:
Nov 06, 2011 | Polaroid i1437 Digital Camera
I have the Poloaroid i1437 digital camera. The lens appears to be jammed in closed position. I have tried several different techniques to try to allow it to operate properly with no luck. When I power the...
The lens assembly is jammed or defective. Check to see if the camera is still under warranty, if not your best bet is to buy a new one - repairing these devices is difficult.
Mar 06, 2011 | Polaroid i1437 Digital Camera
Lens won't close
Please charged your battery fully & then try. If same thing going on then i say ,Yes its a problem of internal zooming function. Some slot is damaged or dislocate & your camera motor make noise. Its need service & after that it will work.
Look at this picture, you will see then what place is damaged.
Feb 06, 2010 | Polaroid i737 Digital Camera
Camera wont zoom it just says turn off
It sounds like you have a damaged zoom servo.. which is odd because you're camera probably extends the lens once it's originally turned on. The motor/servo is kind of expensive to replace and it may be more cost effective to purchase a newer camera.
To make sure i'm correct. try turning your camera on with your hand over the lens to stop it from protruding. if you get a similar or the same message then it's the motor. If it just beeps then i have no idea what the issue is. Has the camera been dropped recently?
Dec 19, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Samsung s730 wont turn on even with fresh batteries???
The lens mechanism is jamming by the sounds of it.
You may be able to free it with gentle manipulations
I guess there is no repair option.
Sep 01, 2008 | Samsung Digimax S730 Digital Camera
Lens stuck open
In a nutshell, this error happens when the lens gets stuck while trying to extend and comes slightly out of alignment. Particularly if it's been dropped while open. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
If your camera is still under warranty, the best thing you can do have Polaroid should fix it. If your camera is out of warranty, or if Polaroid refuses to repair it for free, the one thing you can try is to If you gently, and I do mean GENTLY push against the lens with the PALM of your hand as you turn it on, it may cause it to depress back into the camera. If that doesn't work, and you can't reset it or turn it on/off several times, then you may have to send it in for a repair estimate anyway.
Dec 04, 2007 | Polaroid i832 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Won't turn on! Possible lens problem?
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Jun 16, 2007 | Polaroid i733LP Digital Camera
Polaroid i1437 Digital Camera Logo
217 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
