Problem caused by Device Driver - Computers & Internet
  • 13,433 Answers
The device driver has a problem, it has to be updated or removed to fix the problem from happening again.
Posted on Jul 08, 2008
Why do i keep getting an Error code 32 on HP DV7?
error 32 usually means that you are having a problem with a driver
Code 32 is an error generated by the device manager. The device manager is a native Windows tool for performing administrative action on hardware devices and their respective drivers. When a driver experiences a problem, it reports it to the device manager. These errors are not uncommon, but may be causing detrimental damage to your computer and causing the loss of functionality of one or more of your hardware devices. Hardware devices (video card, sound card, printer) utilize drivers as a resource for interfacing with the operating system. These basic functions are essential for the normal operation of your computer.
The Code 32 error message indicates that the device driver or required services associated with the driver are disabled. Drivers are often supplemented with services that provide functionality and process support for general device operations. Typically, when this technology is implemented, the services provide essential functionality for the device and may cause the device to malfunction or be unresponsive, if not active.
Common causes of Code 32...
  • A required service associated with the device driver is disabled.
  • The device is not up-to-date.
  • The driver is corrupted.
  • A previous attempt to update the driver failed or was interrupted.
  • The device is not configured as the default.
  • A different device is providing default functionality
if you have a few hours to spend manually pin pointing the Driver that needs to be updated or reinstalled go to the link below. Manually Fixing Code Errors
If you are lazy enough to pay 29$ to do it the easy way use this link.
http://www.windowsanswers.net/go.php?r=driverupdate
you will be able to get a driver update software as a set up file it will scan for updates for your drivers return results of how many it found and when you hit install will ask you to register software for $29 dollars.
But before you any of that I would suggest that you go to the HP link below and hit the scan button and let HP check for driver updates for your computer.
HP Pavilion dv7 1130us Entertainment Notebook PC Drivers
Jul 07, 2014 | HP Pavilion dv7-1130us laptop
Device driver codec 28
Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your bios. If that's the case, a reboot might fix the Code 28.
You might have to visit your computer or hardware manufactures homepage and download the driver for the device.
Good luck
Nov 01, 2012 | Computers & Internet
I cannot uninstall livecam vx-3000 cause this device cannot use on my pc
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Oct 28, 2010 | Microsoft LifeCam VX-3000 Web Camera
I have no installer for my web cam cause i lost it
Sep 22, 2010 | A4tech PK5
Asus K50I model laptop webcam image reverse
Most problems with reversed or up-side down webcam images are caused by the wrong device driver. Try reinstalling the webcam driver, or find the right one.
Sep 08, 2010 | Computers & Internet
Hi, i have a toshiba L355 S7812 and just upgraded to 7 -- everything seems to work except for the built-in camera, and i cant find a driver/program for it....the toshiba program from vista doesnt work....
If the Vista Driver Doesnt Work, You Will need to search out a Driver from Different Make/Model... OR install software such as Driver Genius or similar to Install the correct driver for you...Or... try uninstalling and rebooting..
1) Bring up the device manager. You do that by clicking on Start button and then type 'Device Manager' in the search box. Select the "Device Manager" in the list.
2) In the list of devices, you will see "Chicony USB 2.0 Camera" with yellow bang on it. You will see either code 19 or code 1 as error codes.
3) Right click on the device and then select "Uninstall".
4) In the uninstall dialog, make sure you select the option to delete the driver package from the system. This causes the driver package installed earlier to be deleted.
5) Then in the Action menu of Device manager, select Scan for Hardware changes option. This will cause the device driver to be reinstalled.
Nov 23, 2009 | Computers & Internet
5315
Code 28
The drivers for this device are not installed. (Code 28)
Recommended resolution
Install the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to install the driver.
Code 39
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Cause
There are several causes of Code 39 errors:
  • A required device driver is missing.
  • A required binary file is corrupted.
  • There is a problem with the file I/O process.
  • A driver that is referencing an entry point in another binary file is unable to load.
Reinstall the drivers for this device.
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Thanks
Mar 06, 2009 | Acer Aspire 5315 Notebook
My comp says code 39 can you help
Code 39 Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)Cause
I am sending you a copy of this information in the hopes that it will be of some help in your situation.
Cheers!
Ron.
Dec 16, 2008 | Computers & Internet
BCCode Error
CAUSE loadTOCNode(1, 'cause'); You may receive this error message when Windows attempts to use device drivers that are incompatible with Windows XP. uparrow.gifBack to the top
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue, verify that each device in your computer uses a driver that is compatible with Windows XP. To do so, follow these steps: 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties dialog box, click the Hardware tab, and then click Device Manager. 3. For each device, use the following steps to verify that it is using a Windows XP-compatible driver.NOTE: To narrow down the search, begin with devices that have been disabled. A disabled device has its icon overlaid with a red X.
a. Double-click the device name to open the device Properties dialog box, and then click the Driver tab. b. Examine the driver version. All Windows XP drivers should be version 5.1.2600 or later. c. If you are not sure about the displayed version, examine the driver date. Drivers created before the year 2001 may not be compatible with Windows XP. 4. After you identify an outdated device driver that may be causing the problem, follow these steps to update the driver: a. Insert your Windows XP CD into the CD-ROM drive. If Setup starts automatically, quit it. b. In the device Properties dialog box, click Update Driver to start the Hardware Update Wizard. c. Click Install from a list or specific location (Advanced), and then click Next. d. Click to select the Include this location in the search box, and then type your CD-ROM drive letter in the space below. For example, type D:. e. Click Next. f. Follow the on-screen instructions to finish updating the driver. 5. Restart your computer if prompted.
Sep 20, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
David Payne
David Payne
