Question about Apple iPhone 3G
My iphone freezed and shows apple icon - Apple iPhone 3G
    Novelist:
  • 141 Answers
Use the following steps to restore your device:
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
    my iphone freezed and shows apple icon - ht1414_03--back_up_settings-002-en.jpg
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    my iphone freezed and shows apple icon - ht1414_05--restored-002-en.jpguploads/images/ht1414_05--restored-002-en.jpg" alt="ht1414_05--restored-002-en.jpg" class="h_mi" />
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connectiomy iphone freezed and shows apple icon - ht1414_06--connect-002-en.pngtep.
  9. The final step is to restore your device from a previous backup. Once your device is restmy iphone freezed and shows apple icon - ht1414_08--set_up-003-en.pngiPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new..." If you want to preserve previous backups that iTunes has made, be sure to back up the appropriate directory before choosing to set up as new. To learn more about setting up your device as new, see How to set up your iPhone, iPad, or iPod touch as a new device.
Posted on Jan 01, 2011
My iphone is not showing the chargfing icon yet it is charging, slowly
You may please keep in mind that iPhone battery may drain instead of charge if iPhone is connected to a computer that's turned off or is in sleep or standby mode. If you charge the battery while syncing or using iPhone, it may take longer to charge. About not showing the charging icon, please try resetting the phone by pressing the Sleep/Wake Button and the Home Button both simultaneously after which the phone restarts after some time with apple logo on the screen. -- MS Ramakrishna
Oct 13, 2010 | Apple iPhone Smartphone
Everytime i try to turn on my iphone the apple icon shows up and once the apple icon is gone it shuts off again..it will not turn on at all! HELP PLS!! I TRIED EVERYTHING?
u have to restore ur iPhone so plug in that usb cord to ur iPhone and then plug it in to ur computer and hold the home button and the sleep button down simoltaneously for like 15 seconds and it should show the apple sign and then itll show the usb and then itll say to restore ur iPhone then just wait for itunes to put everything back onto ur iPhone
Jan 28, 2010 | Apple iPhone Smartphone
Apple icon is all that comes up.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Aug 12, 2009 | Apple iPhone Smartphone
Iphone 3G Erase All content and settings problem
DFU means Device Firmware Update. If a restore using Recovery Mode doesn't work you will want to use DFU Mode as a last resort. When placing your iPhone into DFU Mode it does not load the OS before attempting the restore
videothumb.pngWatch the Video!
For your convenience this tutorial is available in video format also. Click the Watch It button to view the tutorial!
To put the iPhone into DFU mode so you can do an iTunes firmware restore follow these steps:
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
Jul 02, 2009 | Apple iPhone 3G
Iphone fell, now has alternating frozen screens
do as i say i think it will work ........... Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Apr 09, 2009 | Apple iPhone Smartphone
Iphone freeze
Hello swarajpal,
Try this to see if it will fix your issue.
Holddown the power button and home button simultaneously for 15 - 20seconds then release. Soon after you may have to press the power buttonagain to restart the device. The iPhone should reset itself without any loss of data.
This should be a simple fix however, if it does not work reply again and I will assist you.
Thank you for using Fixya
ERIC the PHONE GUY
sponsored by Cell Phone Technicians
May 09, 2008 | Apple iPhone Smartphone
Itouch problem
Your itouch is not activated - either you previously jailbroke it and then ran the updates or you never activated / jailbroke the device.
which firmware is it?
try to follow these intructions
http://iphone.unlock.no
Feb 06, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
93 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
