Question about Microwave Ovens
I have a Superba wall oven/microwave. As usual, I went to clean the oven and it started normally but after a few minutes it beeped, the contro panel said F8 E0 and the oven went off. I tried a few times with the same result. The door to the oven remains locked and I can't unlock it.
  • Microwave Ovens Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Dec 31, 2010
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
After I entred the desired minutes, when I press START it does not work. And if I press the ADD MINUTES, it is not working. Please can you tell me any solution. Can this problem be due to not cleaning the...
HELLO.
The steps to the solution are as follows.
Off the microwave oven and it.
Then plug the microwave oven and power on the microwave.
Allow the microwave oven to load itself.
Then reset the timing program.
Test the microwave for normal operation.
NOTE:if the problem persist,cleaning the microwave is the next solution.Below is the solution to cleaning the microwave oven.
  • Remove oven racks and soak them in soapy water.
  • Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • Let the oven do its work; it will heat for several hours, charring off baked-on foods.
Thanks.
Sep 20, 2011 | Kenmore 63652 Microwave Oven
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Nov 20, 2009 | KitchenAid KEMC377K Convection / Microwave...
Microwave Not Working
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 27, 2008 | Amana CW65T Microwave Oven
Control panel went off and hence it stopped working
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download Frigidaire / Whirlpool installation instructions here.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Microwave stopped working for no reason
A microwave can be dead for many reasons.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your tech sheet, you can download it here.
You can download Whirlpool owner's manuals and installation instructions here.
Nov 21, 2008 | Whirlpool MH1140XM Microwave Oven
Kitchenaid microwave oven KBMC140HSO
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Whirlpool RMC275PD microwave won't start
I would first suggest unplugging the oven for a few minutes to give it a reset. On Whirlpool brand microwaves, you will hear a series of beeps when you hit START if one of the following is true: - the control panel is not programmed correctly - the door is not shut - there is a problem with the door latch system - there is a problem with the control panel If you do not have your owner's manual, you can download it here: http://www.whirlpool.com/custserv/literature_search_results.jsp?searchTerm=RMC275PD#literror It doesn't sound like the control panel is locked. When the control panel lock is activated, you will see "Loc" and a lock symbol in the display and only the clock, timer, and oven light will operate. If that does not solve the problem, then you have oneof the other problems as listed above. If you need further help, please reply / add a comment here.
Nov 18, 2006 | Whirlpool RMC275PD Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
