Question about Milwaukee Tool Case Heat Gun
I turn the key, there are lights on. and nothing happens. no click. no dimming of lights. if i turn the key 50 times or more it will randomly turn over.
    Top Expert:
  • Milwaukee Tool Master
  • 42,810 Answers
Clean the battery posts and terminals to shiny clean and tighten the clamp bolts.
Posted on Nov 10, 2013
2011 Suzuki GSX-R 1000 L1 Key inserted, click on ignition, light dims but does not start, a random problem not always
Sounds like there is a short in the ignition wiring 12v side or ground side, check your contacts with a miltimeter and the next time it wont start try jumping the starter to your 12v switched source, bypassing the ignition, It the starter making noise when it does this?
Jan 14, 2014 | Suzuki GSX-R 1000 Motorcycles
Car not starting turn key nothing happens has power
There should be a starter relay under the hood in the fuse box, get someone to bump the key and listen for it to close the circuit. the description should say PCM/ECM/STARTER something along those lines. If it doesn't click you may want to swap it for another in the fuse panel and retry. Be sure to check the fuse for the start circuit. The starter circuit is control by a module so there is no direct wire from the ignition switch straight to the starter. If you hear it click then you may want to use a test light and check for voltage at the starter (small wire on solenoid) while someone else bumps the key.
Dec 16, 2013 | Chevrolet Silverado 2500HD Cars & Trucks
My 2000 bravada oldsmobile wont start is it the sartaer
It depends upon what actually happens when you turn the key. If the engine turns over, but doesn't start, it is NOT the starter. If all you hear is a clicking sound, or the starter motor engages but doesn't have the power to turn it over, then it could be wither the starter or the battery. A quick and easy check when this happens is to turn on the interior light. If, when you turn the key and get the click or no activity, the interior light dims way down or goes completely out, it is probably the battery. If you turn the key and get nothing at all, things are more difficult. The interior lamp test should be performed. If the light goes out immediately, try the battery. If the light doesn't flicker or dim at all, then the problem could be the starter, the starter relay, the Park/Neutral Position (PNO) switch, the ignition switch, or the IGN E (Fuse 22) or IGN A (Fuse 34) fuse in the fuse block under the hood.
Nov 10, 2013 | 2000 Oldsmobile Bravada
When I turn the key nothing happens. No clicks, no crank. All of the lights work properly. No dimming or turning off when I try to start. This has happened a few times before. The first time I put the car...
Ignition switch....the electrical ignition switch. To verify, find the thick white wire in the harness coming from the switch and do two things; first, check for power at this wire, when you switch the key position to start. If nothing, power the wire momentarily with the key in the run position, and your car should start.
Sep 11, 2013 | 2003 Hyundai Accent
Honda odyssey will not start clicking noise when key turned
Did you ever figure this out? I have a similar problem. There is a very light ticking sound when the key is in the on position but not being turned to start. In fact, nothing happens when turned to start now. It did at least click. The batter is good and everything electrical is working in the vehicle without dimming or anything. Jumping also did not change anything.
Nov 23, 2012 | Honda Odyssey Cars & Trucks
2001 hyundai accent won't crank
Shifter ?? why do you bother with a lazy mans gearbox ,nothing but trouble cant beat the manual version ,from your description it sounds like a inhibitor switch failure but i couldnt be sure without the old one cell brain box under the bonnet to be sure
Apr 14, 2012 | 2001 Hyundai Accent
I have a 04 gsxr600 and now it won't start. Dumb me I let the bike sit for winter and didn't disconnect the battery. Turn the key nothing lights start nothing so I pull the battery out charge it reads...
Sorry to say, your battery is dead. The reading you got was under no load conditions. Put a load of about 50 amps across it and the voltage will probably fall to just about nothing if even your lights are pulling it down to probably about 8 volts. Only one solution here - you have to replace the battery.
Mar 17, 2011 | 2004 Suzuki GSX-R 600
My 2004 pontiac grand prix gt wont start when i went to turn it on this morning to go to work nothing happened it just made a clicking noice. The guy at pep boys said that the battery was good. when i try...
if you turn headlights on and turn key to start do you hear clicking? if so starter is possibly bad,lets trouble shoot your problem.suggest you check the fuses under hood in black box,make sure those are good. when you turn the key, you should hear at least a click or else the starter is not drawing current.try turning the headlights on and at same time turn the key and try to start, if lights go dim the starter is drawing current, does it click? if so then bad starter. if no noise at all,,still could be a bad starter.suggest that you remove the starter and have it checked out.also make sure the car is in park for sure before you do any of this. hope this helps!!
Sep 13, 2010 | 2004 Pontiac Grand Prix
Won't start lights dim and then brighten
Did you try to boost battery? Sounds like low charge. Check battery terminals for tight and clean as well as groung connection at body and power connection at starter for clean. If battery OK test for power on starter wires. Large wire will have contant battery power small wire will have battery power when key is in crank position. If power ok on both it will probably need a starter. Hope this helps...Good Luck.
Feb 06, 2009 | 2004 Mitsubishi Endeavor
Milwaukee Tool Case Heat Gun Logo
43 people viewed this question
Top Milwaukee Tool Air Tools & Compressors Experts
John Trevino
Geert Deschamps
Are you a Milwaukee Tool Air Tool and Compressor Expert? Answer questions, earn points and help others
