Question about Canon PIXMA MX850 Multifunction Printer
Mx850 canon all in one. was working fine then the alarm light came on and screen shows error code 6A00??? have tired moving the ink cartrigde device, unplugged and pluged back in ... checked everywhere for paper jam or forign objects... paid to much for this to just throw it out!
I cannot print from my Pixma MX850. I get an error message that the inner cover is open and it is not open. HELP!
Posted on Mar 14, 2011
    Champion:
  • 331 Answers
6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
Posted on Dec 31, 2010
Canon mx850 Error code 6A00
Hello thank you for using FixYa.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma MX850 Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly,where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you will find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
For Further assistance, I am here to help.
Thanks and Keep exploring FixYa
Mar 25, 2011 | Canon PIXMA MX850 Multifunction Printer
Printer stopped working. I just added new ink supply. Alarm light flashes. Printer status says "service error 6A00"--"check printer" "cancel printing and press the ok button." None of this works. And I...
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error code 6A00 comes up. Data line and power cord
That error means the purge assembly is not working properly. Could be a scrap of paper stopping it from cycling properly. The purge unit is the cleaning assembly where the printhead parks, it has caps that draw ink from the printhead to clean and a squeegee to wipe off the excess ink. If the printhead comes to the center, unplug printer and check on the right. If nothing there you probably need a shop repair.
Feb 15, 2010 | Canon PIXMA MX850 multifunction InkJet...
I am getting a error code 6A00
Hi there
Try This
Solution 1:
Solution 2:
Solution 3:
Jan 27, 2010 | Canon PIXMA MX850 Multifunction Printer
Error code 6a00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 14, 2009 | Canon PIXMA MX850 Multifunction Printer
Getting error code 6A00-Canon PIXMA MX850 all-in-one printer
The error indicates that the slide the cartridges run on has debris buildup or a component of the printer is blocking the cartridges ability to slide.
Steps to fix...
1. Unplug printer from power source
2. Slide the cartridges to the middle and inspect the slide for a buildup of "gunk" or pieces of debris. Remove what you see and clean the slide with a lint free rag and isopropyl alcohol
3. Look for any part of the printer that may have become dislodged or moved from vibaration and use and try to put it back in to place.
4. Get some "canned air" at any computer or office supply store and blow the printer out thoroughly.
Plug the printer back in and it should work again.
Oct 29, 2009 | Canon PIXMA MX850 multifunction InkJet...
Error 6A00,under warrenty
Hi
All the best
Solution 1:
Solution 2:
Solution 3:
Oct 14, 2009 | Canon PIXMA MX850 Multifunction Printer
MX850 ERROR CODE 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 05, 2009 | Canon PIXMA MX850 multifunction InkJet...
Model Canon MX850. Display error message 6A00. Turnoff and unplugged printer, replugged in and turn on with same result: error message6A00. What to do?
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 01, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon MX850 printer. will not print and shows error code 6A00
Hi
Here is the codes
Solution 1:
Solution 2:
Solution 3:
Sep 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon PIXMA MX850 Multifunction Printer Logo
486 people viewed this question
old marine
old marine
