Question about HTC Touch P3450 Smartphone
Phone back up - HTC Touch P3450 Smartphone
  • 121 Answers
I have a right way sir...use data cables! take back up by connecting it to computers then transfer to phone or the phone memory may be uncapable to store huge memory back up. check with above clues sir this will surely fix your problem for your phone. THANK YOU
Posted on Dec 31, 2010
How do i remove the back cover to the android 6.0 smart cell phone
if the makers of mobile phone dont wants let you to open the back cover of your mobile phone then maybe you can remove it after voiding the warranty of mobile phone and if your phone have a normal back case for your mobile then you can easily open your mobile's back cover.remember dont try anything because it may remove warranty from your mobile phone.
Jan 14, 2017 | Android Cell Phones
How do i open the back of the android 6 smart cell phone
If the makers of mobile phone dont wants let you to open the back cover of your mobile phone then maybe you can remove it after voiding the warranty of mobile phone and if your phone have a normal back case for your mobile then you can easily open your mobile's back cover.remember dont try anything because it may remove warranty from your mobile phone.
Screen is showing blue background with sad face.
You have had a major problem, try the soft reboot, usually holding down both the vol down & on/off button same time for up to 15 secs till the phone beeps & resets, if that does not get it rebooted & back to normal, then you will have to download "Windows Phone Recovery Tool" to your computer plug you phone into the computer & allow it to reinstall the firmware to run the phone, this will be a full install but if you have backed up your phone & or had it on auto backed up to one drive, it will put your last back up of apps etc back to the phone, you will need to sort your start menu again though, good luck, if you have used the phones back up systems, then its never to much to get it back, you can get a new phone to the same as your old phone on initial start up by choosing the stored settings of the last phone you backed up. good luck
Jul 11, 2015 | Nokia Lumia 520 Windows Phone Black
Iwant to change screen on phone
    • 1 Power off your cell phone completely by holding down the power button for four or five seconds. Turn the phone over and remove the back plate. Slide your fingernail underneath the battery and pop the battery out of the phone.
    • 2 Locate the SIM card if your mobile phone is a GSM style phone. Pull back the metal covering over the SIM card and then remove the card. Set it aside.
    • 3 pixel.gif Removing the RF grommet Find the plastic RF grommet at the bottom of the phone near where the battery was located. Grab the grommet with a pair of tweezers and remove it from the phone.
    • 4 pixel.gif Removing the bottom cover Insert the tweezers into the hole on the side of the phone opposite from where the RF grommet was located. Use the tweezers to pull up on the latch inside the hole to unlock the bottom plastic antenna cover. Lift the cover off of the phone and set it aside.
    • 5 pixel.gif Metal plate Pull out the screws along the edges of the phone using the Torx screwdriver. Take the metal plate off of the phone.
    • 6 Flip the phone over so that you can see the LCD screen. Slide the edge of a flat head screwdriver in between the seam of the plastic cover on the bottom of the phone. Wiggle the screwdriver up and down gently to unlock the catch underneath the plastic cover. Lift the entire plastic cover up and then off the phone.
    • 7 Find the latch on the side of the LCD screen and unlock it with the tweezers. Pull the screen slightly off of the phone and then disconnect the cable running from the screen to the phone. Lay the replacement screen back into the phone and attach the cable.
    • 8 Set the plastic cover back onto the phone and then flip it back over. Re-attach the metal plate and put the screws back in. Push the RF grommet back into place and then place the SIM card and battery back in the phone. Put the plastic cover on the back off the phone and then power it on to ensure the screen is working correctly.
Tips & Warnings
  • If your cell phone is a CDMA style phone, such as those provided by Verizon, it will not have a SIM card for you to remove.
  • Replacing the LCD screen on your mobile phone voids your warranty provided by the phone's manufacturer.
Feb 22, 2012 | Sony Ericsson Cell Phones
I have omnia i910 samsung the screen froze and do noting
Try removing the battery from the back of the phone by removing the back cover. There should be some kind of button or latch on the back of your phone to push to release the back cover. Remove the battery and that will shutdown your phone. Put the battery back in, close the back casing, and restart your phone and everything should function normally. If you can't figure out how to remove the back case, just let the phone's battery run down and you should be able to restart it then also.
Mar 05, 2011 | Cell Phones
My LG cell phone screen is frozen up.
Try a battery pull to start:
  1. Remove the back cover.
  2. Pull out the battery for approx 45 secs.
  3. Re-insert the battery and cover.
  4. Power phone back on.
Please reply if this does not work. Thanks!!
Aug 22, 2010 | LG RUMOR Cellular Phone
My sony ericsson cell phone doesn't work anymore, I tried to change the batterie but nothing change. please I need some help to fix my phone I neeeeeeeeeeeeeeed my friends' numbers.
HI, to restore back the phone,i think you might loose all data during the process of restoring the phone.
To restore back the phone, you will need to flash the phone back to life cause memory is dead.
Use thislink torestore back the phone memory:
FORMATTING PHONE
Hello, Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this link.
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Jun 23, 2010 | Sony Ericsson Walkman® W880i Cellular...
How to unfreeze samsung a736
Well first of all you can just remove the battery from your phone, the battery is located on the back side of your phone, Remove the back cover of the cell phone. Some Samsung phones have a plastic outer cover over the battery, while on other models the back of the phone is the back of the battery itself. Locate the release button or slider on the back of the phone. Depending on the Samsung phone model, the back cover or battery itself will slide downward or lift off when the release button is pressed or the slider is pushed upward.
Just insert the battery after 30 seconds, and then turn on your phone. hope this helps. Please post comment if further you have the same problem.
Good Luck!!
Thanks
Jan 12, 2010 | Cell Phones
Freezing up
Have you had your phone updated lately if not call in to your cell phone company and ask them to do a up date on your phone and when they up date your cell phone turn off your cell phone and re-turn it back on.
If this dont work take your battery out leave out for 60 seconds and put battery back in and turn phone off and back on.
Nov 27, 2007 | Motorola Mobility V551
My phone keeps freezing...
my phone froze and i attenpted to turn it off several times, after trying and not getting a response i took out the battery pack and placed it back in and turned the phone back on. after turning the phone back on it kept freezing a
Nov 24, 2007 | Nokia N81 Smartphone
HTC Touch P3450 Smartphone Logo
13 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
