Question about Intel Core 2 Quad Q8400 Computer System Desktop Pc
Hi I just bought a Intel Core 2 Quad q8400 for my gigabyte GA-G31M-S2L. It won't boot up!!! It freezes when I try to enter bios setup and if I do manage to get in, it freezes at the options screen. It also hangs at verifying/building DMI pool. I have tried reseting CMOS, still the same problems occured. Core temp is fine running at 35-40 degrees celsius (managed to get into PC health status before it froze up). I have flashed my bios with the latest bios that supports the CPU. The old CPU works fine which is a Intel Core 2 Duo e6320. Thanks for your help
    Champion:
  • 331 Answers
What size power supply are you running? If you are not running a minimum of 400watt , I would anticipate issues with this type of processor. Since it is freezing right away, it could be bad memory. You can try memtest86.com to download a memory test tool to verify.
Secondly, you may want to reset the board by moving the jumper from normal mode to reset mode.
last thing, it's not impossible for a processor to be bad. Since it is an Intel processor; it should have a 3 year warranty on it. Any dealer who sells Intel should be able to warranty replace it for you.
Posted on Dec 31, 2010
  • Cefir0 Dec 31, 2010
    Hi im running a 510watt power supply.
    I will try the memory test.
    I can't find any jumper linked to normal mode on my motherboard
    I guess ill replace it if these methods don't work
    Thanks
Booting operating system to install from usb
rather disconnecting the dvd you could just uninstall your dvd drive then reinstall it after
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives right click select uninstall
or
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to usb,press escape then press f10 to save to cmos to restart
or
http://www.bootdisk.com/art/penboot.jpg
hope this helps
Oct 09, 2012 | Gigabyte Ga-g31m-s2l Motherboard Intel G31...
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Mainboard GA-G31-ES2C Warning: Backup BIOS checksum error BIOS Auto-Recovering...
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen to press delete to enter setup
Jul 23, 2011 | Gigabyte GA-G31M-ES2L Motherboard
My computer have an Intel Dual-Core Processor installed in a Gigabyte GA-G31M-S2L motherboard. I re-installed Windows XP and when the computer reboots itself the video was gone and didn't come back in...
Do you use your intergrated video? have you been into the bios and checked that it has not been disabled?
Try boot into safe mode (F8) do you get any video?
If your still not getting anything, write back and we can try something else
Sep 05, 2010 | Intel Motherboard
WHAT IS THE APPROPRIATE CPU FOR GIGABYTE GA-965P-DS3
This is a socket LPA 775 motherboard, it will accept almost all core 2 / quad core intel cpu's, here is the full list from gigabyte.
(you may need to unpate the bios for some CPU's)
http://ee.giga-byte.com/products/mb/cpulist/ga-965p-ds3_20.html
Sep 01, 2010 | Gigabyte 965P-DS3 (GA965PDS3) Motherboard
How can i give BIOS password in Gigabyte GA-G31M-ES2C Motherboard ?
Once you enter the BIOS, Select "Set Supervisor Password" option. For detailed explanation, please check Page 53 of the manual provided here.
Mar 09, 2010 | Gigabyte GA-G31M-ES2L Motherboard
Ga n650sli ds4l and intel core2 quad blackout when i restart
You need to reset your computer bios back from its original settings. While turning on your computer keep pressing the del key on your keyboard until you get to the BIOS utility screen. Select the BIOS default option and then save settings and exit.
Dec 18, 2009 | Gigabyte GA-N650SLI-DS4L Core 2 Quad...
I have gigabyte series g31 m-es2L i want use memory pc 5300.... it's support with this mainboard ???? tx pls reply to : it_mid@yahoo.com
First, clarification: the closest Gigabyte model is GA-G31M-ES2L... there is no "g31 m-es2L"
For this kind of question the easiest way to find the answer is from the manufacturer: Gigabyte
A quick search of their products results in:
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2889&ProductName=GA-G31M-ES2L
which states that up to 800mhz DDR2 (PC6400) is supported
( 667mhz (PC5300) is also supported. )
Generally with motherboards, if a higher speed of memory is supported, the lower speeds are also supported.
PS: mhz times 8 yields the PCxxxx number, PCxxxx divided by 8 yields the mhz number
Feb 09, 2009 | Gigabyte Matx Intel G31 775 DDR2-800...
Intel Core 2 Quad Q8400 Computer System Desktop Pc Logo
286 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
