Question about Fujitsu Heating & Cooling
Air con not working. Operation and timer lights flashing, then operation light flashes and then lights go off. Air con is blowing air but the outside unit is not blowing any air.
  • 2,133 Answers
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Posted on Dec 31, 2010
My LG air con was working and now it's stopped and there is a gree light flashing 7 times the a pause then 7
7 Flash==== Different Operation Mode
Indoor Unit is Set in Different Cool/Heat Operation Mode.....
Jan 14, 2016 | LG Heating & Cooling
The unit is working but Operation and timer light flash 4 times then timer light flashing 3 times
It depends on the model as some models error codes differ slightly but this is the typical code for operation x 4, timer x 7:
VDD permanence stop protection (Electric air clean)
When the air cleanness monitor trial protection operates 4 times.
> Only clean air permanent stop.
[Diagnosis Point]
The front panel is closed.
The foreign body such as dust doesn't adhere
Aug 30, 2015 | Fujitsu Heating & Cooling
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Timer light flashes twice on my asta09lcc but it wont work
If operation light is normal and timer light flashes twice, the error is:
Serial signal (reverse) error, at operation start up
Most likely a faulty outdoor controller PCB. Around $250 for new board plus labour.
Jul 09, 2012 | Fujitsu 18C1 Air Conditioner
My a airconditioner has both operation and timer flashing at the same time.there is no fan working on the outside unit there is no cold air coming inside.is this something to do with the control
I have one that the operation light flashes 7 times and the timer light flashes 2 times. Error code says Discharge pipe temperature error. Is there an easy fix?Thanks!!
Jan 19, 2011 | Fujitsu Heating & Cooling
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
Outside unit not working
you most likely need a service guy to go out and take a look
Mar 15, 2009 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
1,352 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
