Question about Samsung Refrigerators
Refrigerator fan making huge noise model s33bh1/mghl/xtl
  • 472 Answers
I not only am a appliance /a/c and heating company owner i happen to own this same model refrigerator ... after three months the same problem happened and i had to pull the back panel in freezer to get to fan the unit was frosting up .... i unplugged took a hair dryer and thawed out ...the noise will most likely stop however will come back they are having problems with both there fans and the defrost thermostats on these models... hope this helps a/c and heating unlimited texas
Posted on Dec 31, 2010
How hard is it to change the refrig side fan motor? Its making a racket! noise stops when door is open, fan shuts off The motor is inside behind a couple of panels. samsung RS265LABP
Sears parts department has a huge library of breakdowns of many appliances from all major brands. I ran your model number and it is included. The line drawings allow one to fairly accurately judge the location and access to internal parts:
Your Samsung
You should be able to replace your fan using the illustrations and in many cases, the correct part can be ordered from those pages.
Sep 06, 2011 | Samsung RS265LABP Side by Side...
I have an Admiral top=freezer refrigerator model LTF2112AR. Suddenly, this evening, the motor in the back of the freezer began making continuous noises, it sounds like a grinding noise, but it is still...
Is the compressor making the noise or is it the fan motor that is making the noise. If the compressor then you are looking at over $500 for replacement and you will have to decide if your refrigerator is worth that type of investment.
But if it is the fan motor, then you could replace it yourself. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170333 Item 11 is the fan motor and you could replace it. The compresson is item 1 and would require a trained person to replace it.
Jun 16, 2011 | Maytag Admiral Top-Freezer Refrigerator
My refrigerator makes a noise when i close the doors only, when their open the noise stop model # lfc 25760 tt
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Apr 17, 2011 | LG Refrigerators
New model ET1CHEXYQ02 VERY NOISY, LIKE TO MAKE
Hello there
Please follow these steps first ok
It's noisy Noise can come from these areas: The inside of the freezer The outside back of the refrigerator The bottom of the refrigerator The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows: If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer. If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer. If the freezer is on the left, the fan is on the back wall, halfway up or near the top. Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead. To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it. The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting). The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly. If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor. The defrost timer is often located at the bottom of the refrigerator it may make noise
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Loud humming noise (vibration) from freezer section when running. Amana refrigerator (freezer on bottom) model BC21VW
Remove the back panel and see if the fan is turning. You will need it in the running cycle with the door switch closed. The noise your hearing is probally the fan assembly AP4008960. Make sure it is mounted tight and the back panel is not rubbing or loose. If the fan is making noise with the panel removed replace.
Mar 24, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Loud noise behind frezzer while refrigerator is running...
There is a fan responsible for 'stirring' the air and distributing it partly to the refrigerator and the sleeve bearing is probably worn and allowing the blade to hit or just vibrating enough to cause the noise.
Sear's website is linked to their parts department and they have a huge library of line drawings for most brands of appliances which can help locate parts in an appliance and often the required parts can be purchased through them for many models besides Kenmore. If they have yours listed, you should be able to tell how much work it is to access the fan.
Go there and enter your model number to see how your luck is today.
Feb 22, 2010 | Frigidaire GLRT184RA Top Freezer...
Our 8 year old refrigerator has recently begun making a continuous tapping sound. The sounds stops when you open the bottom freezer door.
the compresor fan is might make that sound or the fan in your freezer is tuching something like build up ice... see if you can reach it and clean it.
Jan 01, 2010 | Refrigerators
Refrigerator makes lot of noise
titu, can you be more specific on what kind of noise you're hearing. If it's a squealing noise I would suspect either the evaporator or condensor fan. See if you can isolate where it's coming from. Catriver..post back.
Oct 12, 2006 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refrigerators Logo
124 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
