Question about HP DeskJet 3740 InkJet Printer
My hp 3740 Printer's power button is blinking and doesn"t print since yesterday.
  • 27 Answers
Blinking power light can mean a jam, out of paper, open cover, or bad usb cable.
Open the covers and look for torn paper and nothng blocking the paper sensor. Check and make sure your USB cable from PC to printer is connected.
Posted on Dec 31, 2010
2 Suggested Answers
  • 8 Answers
SOURCE: HP Laserjet 3740 printer will
one or both cartridges are error
Posted on Nov 23, 2010
The green light keeps blinkyng
If the power light is blinking it is an indication of an issue with the printer. Check to make sure there are no paper jams or open covers, make sure there is paper. If there are any error messages please post them. Try going into the printer tools, To gain access to the tools,
open the Printer Properties dialog box, click the Services tab, and then click the
Service this device button.
Use the printer tools to perform the following tasks:
• View estimated ink levels.
• Clean the print cartridges.
• Calibrate the printer.
• Print a test page.
• Perform other functions as needed.
Aug 20, 2011 | HP DeskJet 3740 InkJet Printer
I got a refilled hp 27 cartridge refilled at a local office supply store and installed it into my hp deskjet 3740. It prints in "normal" mode but the text is faded. I used the calibrate and clean...
It is probably the "refilled" cartridges. Return them and buy a know good brand. Office Depot's brand seems to work fine in my HP printers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | HP DeskJet 3740 InkJet Printer
Power switch blinking
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Nov 12, 2009 | HP DeskJet 3740 InkJet Printer
Cant i run a stand alone self test on my deskjet
o check printing capabilities, print a Self Test Report. In order to print such a test follow the next steps:
  1. Turn the printer on and place media in the tray.Set the width adjusters to fit tightly against the sides of the paper in the tray.
    1. Press Power button while opening and closing the printer access door four times.
    2. Release the Power button.Your printer will print a test report.
Oct 28, 2009 | HP DeskJet 3740 InkJet Printer
HP Deskjet 3740 Series
You have to go www.hp.com select your region and product then you have to choose OS and now you can printer's driver for free for life.
Your problem will solve.
Aug 04, 2009 | HP DeskJet 3740 InkJet Printer
Light is flashing and will not print
dude..u didnt mention printer's make n model nyhow give a try to dis one..
Remove all the cartridges and the paper from the printer...Power off the printer...unplugg the power cable from the back of the printer...while printer is unplugged from the power..press n hold the power button for atleast 60 seconds then release it..open the back door of the printer and look for any paper jam...remove paper from behind (if any) and roll the rollers in upward direction from behind..close the back door and connect the power cable to the printer and power on the printer..Look for the cartridge slots and clean it wid a lynt free cloth and the copper contacts of the cartridges as well...then insert only one cartridge (black or color) and close the cartridge door and check for any blinking lights on the printer...similarily repeat it with the other cartridge..by this u wud get to know if any cartridge is faulty? If u get blinking lights on the printer ...that means there is some problem,,,
Once you see the steady green light on the power..it means the printer is ready..You can also print a test page..."Press n Hold the power button down...while holding the power button down...either press "Down Arrow button" 4 Times OR "Red X button once"...then release the Power button to print the test print..
If it prints ..u r the master !!!
Best of luck
Remember if there is any blinking light,,the printer wont prin..
if the light blinks around the drops..it means there is cartridge issue and you may even replace the cartridges..make sure u remove the pink tape carefully before inserting the cartridges.
ALL THE BEST
May 08, 2009 | HP DeskJet 930cm InkJet Printer
Blinking light--won't print
Best of luck
ALL THE BEST
Mar 22, 2009 | HP Deskjet 6940 InkJet Printer
Blinking Light with no cartridge problems
I believe this is normal with HP deskjets. I have a different model but HP deskjet 3740, which also gives a blinking light when there is a pending print job and or printer has run out of paper. I usually get rid of this problem by putting some paper and most importantly removing and re-plugging the printer power cord (which does a basic power reset on the printer and causes a refresh of pending print jobs). I hope this works for you too.
Jan 27, 2009 | HP DeskJet D1460 InkJet Printer
Power light flashing really fast
problem with the cables ,
the light blinks faster if any of the cable is lose or disconnected .
Aug 27, 2008 | HP DeskJet 3740 InkJet Printer
HP DeskJet 3740 InkJet Printer Logo
293 people viewed this question
Seeker5211
Seeker5211
